HornedHelmet
- Apr 6, 2020
- Virginia, USA
- 2017 MX100D, 2019 M3P, 2024 CB
- Publishing Manager
I'm looking for some help from someone who has been successful using their 220V outlet in the CT bed to power the mobile charger to charge another Tesla.
When I set this up, the mobile charger indicates it has power (1 green steady light), but when I plug in the charger to another Tesla (Model 3), the charger clicks after 1-2 seconds and power is lost. I can reset everything, but I get the same result. It seems like the internal GFCI for the mobile charger is tripping. I have tried different variations to see if I can localize the problem on a piece of gear, but no luck. tired using different mobile chargers (but they are Gen1--don't know if that makes a difference),
The one thing I haven't tried is to power something else other than a Tesla charger with the 14-50 outlet. I have no other device that fits that. I believe it is providing power based on the CT screen and the green light on the charger when plugged in (before trying to pull current through it.)
I suspect either I am missing some configuration setting or that my Gen3 mobile is somehow defective.
I set up a service call, but I'd still like to figure this out, if I can. Any ideas?
Thanks!
- tired using different mobile chargers (but they are Gen1--don't know if that makes a difference)
- tried charging a different Tesla,
- tried dialing down the amps from 32 to 10,
- confirmed that mobile connector works with wall 14-50 outlet,
- tried hooking things up in a different order,
- tried all combinations of resets
Thanks!
