- Michael
- Dec 20, 2025
- Chicago
- Website
- www.getcyberglow.com
- 2025 Tesla Cybertruck
hemiarch thank you for the update.Thank you Michael. Kind of getting used to the always on vibe after a day or so.
In the daytime it looks kind of interesting with the prism hex film I have on the beast bar. much more subtle when driving because the white is on behind it. Kind of what you want for minimizing pull over risk anyway. Will probably mount your switch right by the auxbeam. Iāve found also that since that since itās related to the ākeep aux power onā feature it can be turned off remotely by putting the car in low power mode through the app. You canāt turn it back on, but you can turn it off that way. After that, if you still want cabin overheat and sentry and that sort of thing , you just turn it back out of low power mode
Thatās exactly what we tend to see once people live with it for a bit. When youāre driving and the OEM white is on behind it, it stays more subtle which is usually the sweet spot for daily driving and keeping it low key.
Mounting the switch right by your Auxbeam makes a lot of sense. Super natural spot for it. Iām thinking about possibly making a holder for it. Let me know your thoughts
Also great tip on Low Power Mode. Youāre 100% right. Because itās tied into the vehicleās aux power behavior, Low Power Mode is a reliable way to shut it down remotely if you ever need to. And like you said, you canāt turn it back on remotely, but being able to kill it in a pinch is huge. Then you can pop it back out of Low Power Mode and keep Sentry, cabin overheat, etc running.
Appreciate you sharing that with the forum. That kind of real world workflow is exactly what helps other owners know what to expect and how to control it.
