IIIEnforcerIII
- Steve
- Feb 5, 2025
- Rigby, ID
- Cybertruck AWD
- Higher Education. Professor & Administrator
Well, Fall is now over and that means my hunting is done for the year. Brought back 1 deer and 2 elk for the season. It made me reflect a bit on the last year with the truck--and using it for hunting specifically.
Overall, it worked. But just barely. I've been trying to think of ways to make this truck work for hunting in my spot for years as I waited. I imagined up all the same power station and solar combos many others have. But they are a ton of money and take up lots of space. Here are my thoughts after a hunting season under my belt with it.
My problem is that I hunt central Idaho--near Mt Borah and Arco, Idaho. I also have a cargo trailer I've built out to camp in. My 300 mile range gets cut to about 120 miles while pulling the trailer and gaining elevation like that. There is a hokey charging station about 85 miles into the trip. Its only a 125kw charger buts its all there is in the middle of nowhere and one of only a few that the govt put in with all that money for charging infrastructure. So.....super happy it exists at all. But we have to stop and charge there for 60-75 minutes to get 100% before continuing on. We go another 50 miles and turn off the paved roads and then its 1-2 hours on slow, rocky, nasty roads. Range anxiety might not be too bad on well-used highways, but for us hunters and explorers its very real.
Instead of expensive solar setups, I took my 4750 harbor freight inverter/generator on each of the 3 hunts. With its 30amp output (only 23 or so usable without tripping the charger), I can get 5-6 miles per hour running. So in the evenings, I'd run it for a couple hours. Kind of obnoxious (quiet solar would be better). The cold nights would sap away 15 miles by morning, but at least I was keeping up with the drain. Then before leaving, we ran it for 3-4 hours as we packed up and relaxed a bit. It worked, but just barely enough to get us back to that same charger with 10-15 miles to spare.
Thoughts after nearly 1 year plus 3 hunting trips.
- Love driving it. mostly a commuter.
- People mostly accept it......now.
- Tech is great. Systems & Software are amazing.
- Space was good. Love having the higher bed panels which allows you to cram more in the bed and still keep it covered.
- One one trip (September) I even spent 1 night in the bed with the cover cracked open. Definitely was cold at night, but turning sideways a little was doable in a pinch.
- Loved the air suspension and being able to raise when needed.
- Glass roof I would sacrifice for $$$. I thought it would be cool in the mountains. But it mostly didn't help the view. Only saw a reflection of what is inside the truck. If that adds $1000 or 2000. Its easily take that money instead. My son-in-law nearly cracked it accidentally gettingin the truck hitting the barrel of the gun on the ceiling.
- 4-wheel steering is great, but I wish they hadn't done it. Nice and nimble, but my F150 was fine without it. If its another thousand or two, I would have taken that off the price gladly as well. Plus more expensive parts to go bad and worry about messing up.
- Spare tire is a pain. Have to take up most of the bad with it, plus a beefy floor jack, tire iron, and inflator. If Rivian could find a way to package on in a smaller truck, I think Tesla could if they had wanted to.
- Truck performed well over the nasty terrain. Was able to digitally "disconnect" trailer so I could raise the suspension even with the trailer on to avoid some dips and spots where I would have drug my tongue.
- Sure wish we could connect the truck to satellites for way off grid trails.
- Another problem with the glass roof is no grab handles. From my older mom that I take around some times, to just getting in easier and taking weight off the seat edges, to off roading. Its just unimaginable that a truck doesn't have handles. If an updated truck came out today with no other feature besides that, I would seriously consider it for that one thing alone. When you're on a rocky trail, the driver is fine with the wheel, but anybody riding is just sloshed all over the place. Its terrible.
