Weight Limit of L-Track?
BillSirloin
Austin
Model 3
Hey everyone. I’m about to buy a foldable tent that I plan to put in the bed of the truck with some mounts on the L-track. Does anyone know the weight limit that the L-track can support? I see the Cybertent is mounted on it alongside some collapsible legs but don’t want to break anything. Thank you in advance.
BillSirloin
BillSirloin
Austin
Model 3
Kryptek
Alaska
I can stand on my MOLLE bench that uses an l rack on each side, 2 nuts each side and it holds me 186lbs. There is some flex In my
MOLLE but that’s more on the metal composition than the brackets. I’d say about 300-400 while off roading
MICyber
Michigan
2024 Cybertruck
Not that this is a limit of the track. The molle panel Tesla sells says max 100lbs. It is only anchored in three points so I'm sure it's hundreds of pounds. The tent seems to be solely supported by both tracks and a couple of people + the tent weight is supported.
