Range and tire pressure
zeusss
Ryan
CT20244me!
2024 Cybertruck AWD
Teacher
So my service center filled up my tires(3lbs low) and my range improved drastically. I'm averaging 20wh less consumption since the visit. I had them fix a few small issues from delivery and they checked my Pirelli AS tires and filled them. They were technically warm so when the temp dropped a couple days later so did the tire pressure. I refilled them and the efficiency went back up. These AS Pirellis really need the 50psi cold pressure for efficiency. I know tire pressure makes a difference but 2-3 lbs seems wild to me for that kind of impact.
My understanding is that low tire pressure will definitely have a negative impact on range, but overinflation helps little if at all.
It needs to be "just right". Like Goldilocks lol
dw321
Ram 2500, Toytota 4 Runner, Bikonit Ebike
Does the Cybertruck monitor tire pressure for you? If not I wonder if a Tire Pressure Monitor System would be a good addition??
zeusss
zeusss
Ryan
CT20244me!
2024 Cybertruck AWD
Teacher
It does monitor pressure but doesn't throw an alert until its lower than this. So it's not dangerous but less efficient. In the winter efficiency starts mattering more.
dw321
Thanks
DaBagBoy
Lansing MI
3, Y, CT
I don't really understand that first sentence? your range actually improved with low tire pressure? I just topped mine off from 47 PSI to bring it back up to 50PSI due to the colder weather?
zeusss
zeusss
Ryan
CT20244me!
2024 Cybertruck AWD
Teacher
After they filled my tires my efficiency improved. I wasn't surprised at an improvement due to less rolling resistance with less surface pressure and so on... but rather how much it improved surprised me. I can't imagine how much difference AT tires with low pressure would hurt efficiency.
