Powershare Voucher Scam
stangfish
Stan
Bay Area
I got a $700 voucher as a result of buying a FS Cybertruck with Powerwalls and wall charger previously installed. I started using the voucher to make an $80 purchase on the Tesla website. That worked great. When I next went to the website to make an additional purchase using the voucher I was told it was not a valid voucher. My assumption was it would work like an Amazon gift card but I guess it doesn't. Apparently it is a one-time use regardless of the dollar amount of your purchase. Before you ask, yes I double-checked the voucher number to make sure it was entered correctly. Has anyone else experienced this?
jf64k
IIRC, the “use it all or lose what’s left” provision was in the T&C for the voucher?
Gigahorse
AWD
So instead of having $620 it is $0?
Would contact tesla on that, if there was only lke $20 left on it oh well, but thats a lot, considering you can only spend it there and what a value difference there is taking the voucher vs wall charger.
Hbrueckland
Hause
Arkansas, USA
M3LR, MXLR+
Accounting Consultant
Can you cancel/return your $80 purchase, to get the full voucher back, by chance? Crazy!
Art138
Art
Weston,Florida
MYP,Ford GT & FS CYBERBEAST
According to this you should be able to make multiple orders:
Thank you for completing the Powershare Home Backup survey. Because you already have Powerwall installed, your home is on the way to being fully configured for Home Backup.
To finalize your Home Backup setup, you need to have home charging backed up by your Powerwall. When using Powerwall, Home Backup is compatible with any home charging unit, but 240V charging will provide the best experience. Our recommended home charging solution is either Wall Connector or Universal Wall Connector. To confirm whether your home charging is 240V and backed up by Powerwall, follow the steps below.
In place of Home Backup equipment, you will receive a $700 voucher for Tesla Shop. You can use this voucher to purchase home charging to complete your Home Backup setup – or to purchase other charging equipment, apparel, accessories and more. For help installing your preferred home charging solution, contact a Certified Installer listed on our website.
LoL Rick
Rick
Land O Lakes, FL
2014 S 85, 2018 3 Perf, CT AWD
Retired Software Developer
This is in the fine print at the bottom of the email:
" This promo code can only be used once and must be applied towards Tesla aftermarket products or apparel sold exclusively on shop.tesla.com. Any unused balance remaining after the transaction will be forfeited. "
cybercoffee
MYLR
geez that's infuriating! I had also been under the impression that it was a credit to be used bit by bit, like the referral points, but now I guess we know otherwise...I guess everyone in the family is getting a cyber owl tee
stangfish
Stan
Bay Area
That is some seriously fine print.
rrolsbe
Ron
Reno, NV
2023 Model 3 RWD
If you answer the survey and tell Tesla you already have a Powerwall (any version) and the older version 3 Wall Connector installed you get a $700 voucher. I thought Power Share required the newly released Universal Wall Connector? Do you at least have the option to choose the new Universal Wall Connector (even though I guess it can only be shipped to a Tesla certified electrician)? You can order a V3 Universal Wall Connector from Best Buy and have it delivered to your home address then you can choose the Electrician (maybe you).
CybertruckRN1127
Palos Verdes Estates
Model S, Model 3, Model X
I think it was already posted here that the voucher was one time use. It didn't get a lot of traction because it was probably buried in someone's reply under a different topic. I remember reading about this a few times somewhere. Hopefully Tesla allows a refund and give you a new voucher.
jasper7821
Ken
Tesla M3, Jaguar F-Type, Porsche Macan GTS, Indian
Aircraft researcher
Shady fine print if you ask me. That sucks they would do that.
I think it’s obviously written so you wouldn’t read the full disclaimer and think it’s like a gift card where the balance goes down after each purchase.
