Phone key issue
Floridaman
Dan
Tampa, FL
Cyberbeast, 1972 Chevelle SS, WRX, 1984 M-1009, M35A2, etc
Hey!
I've had my 'Beast for about 5 weeks (5000 miles!!) now and absolutely love it! I am definitely using it as a truck and have had tons of things in the bed, towed, etc with it.
A few days ago, my phone key stopped working. Up until then, other than having to turn my Bluetooth on and off occasionally, it worked perfectly. Then...not so much!
The phone no longer unlocks or 'starts' my truck. The Bluetooth connection, however works great. If I stream music, it is solid and does not disconnect, etc. Inside the app, the phone key will cycle through 'disconnected' to 'connecting' to 'connected' for a second, then it cycles again . Over and over.
I (Samsung S22 ultra) have deleted the data from the app, uninstalled the app on my phone, deleted the phone key in the truck and reinstalled it and it does not make a difference. The truck will see the phone and add it as a key, then immediately start cycling again ....
Weirdly, my son's Pixel will work even when mine doesn't.
Bluetooth is working fine on my phone, and I use NFC payments, so I know that's working as well...
Any ideas?
UberNoob
CyberBeast & M3P
Desktop Security Engineer
Sounds like you need a pixel or iPhone upgrade. They way you describe it points to a phone issue. Try adding another phone wife, husband, friends etc as the key and see if it improves. I’ll let you add mine just need your address so I know where to snatch the truck while you’re sleeping. Just picking, or am I ?
Best of luck to you.
Floridaman
Floridaman
Dan
Tampa, FL
Lol. Thanks!! I'll keep that in mind as an option...
Lasttoy
Paul
St Augustine, FL
I had same issues yesterday. Turn off all lock options. Rebooted
Turned back on. Fixed it
BeFamousVideo
Vincent
Orange County, CA
CT Beast delivered May 2024
Automation Agency
Make sure your Tesla on your phone is set to connection preference. I have an Android too. Also if you have another Tesla you own parked nearby it could be trying to connect to both.
Floridaman
Floridaman
Dan
Tampa, FL
Finally fixed! If anyone else has this problem with an Android, try 'resetting network connections '. I had to reenter hotspot, wifi, and Bluetooth connections, but it's working every time now.
Thanks!
vinsk
Vin
FL
MYP, Cybertruck FS AWD
SW
Thanks!
I was about to suggest that but wasn’t sure if Android has this network reset option. iPhone has it and I do it from time to time when having issues with wifi networks or 5G connectivity.
Jsul23851
Jack
North Carolina
Two x7s
My iPhone has been hit or miss last few weeks . I’ve had to bring the card as a backup
vinsk
Vin
FL
SW
Do the same thing what OP did! Network hardware sometimes need complete reset.
