Panel gaps and trim imperfections.
Seksyback
DC
So i recently picked up my cybertruck and have an appointment set to fix some problems with panel alignments. Would you guys mind telling me if I'm being too nit picky, and which ones I should definitely get fixed.
I attached some pictures.
First issue tesla sc says they can repair is the misaligned tailgate, left side is just sitting high.
2nd issue is the roof trim on the right side. It seems to bow up in 2 places. I can press it down and here a snap, but it'll bow back up later in a few days.
3rd issue is the cantrails trim, left side looks perfect to me. The right side has a large gap. The assymmetry just bothers me.
4th issue, which I'm not sure if it's large enough of a problem to fix, is the left rear quarter panel. it's not straight like the right side. There's an area that curves outwards leaving a wavy bump.
Tesla Roadster 2nd gen Panel gaps and trim imperfections. 20250216_140353
Tesla Roadster 2nd gen Panel gaps and trim imperfections. 20250216_140405
Tesla Roadster 2nd gen Panel gaps and trim imperfections. 20250216_140502
Tesla Roadster 2nd gen Panel gaps and trim imperfections. 20250216_170852
Tesla Roadster 2nd gen Panel gaps and trim imperfections. 20250216_140345
yeah, those are quite far out of spec. The sail doesn't look quite that bad though.
Seksyback
DC
That's what i thought, i scheduled an appointment on the 26th, hopefully they get fixed. I'm pretty sure the sail panel will be within spec though, since I see similar sails on pictures posted in this forum.
cybertruckgg
US
Pretty much every gap / trim issue I pointed out the team said within spec and recommended not having them tweak as they'd potentially put other panels out of alignment. They said every truck has come with some gap variance.
Maybe things have changed from last year? The one that bugs me the most really is the top bend line of my driver side door doesn't line up with the bend line on the fender panel. I also have some variance elsewhere, including the rear tailgate (it is not flush).
Seksyback
DC
From reading the forums, shouldn't tesla be able to just realign the doors?
JCERRN
J
Around
Yeah
from talking to local sales admin teams, it appears that the “waviness” of the sail quarter panel are most prominent where the clips that hold them in place are, creating pressure points. This is visible on all trucks to varying degrees.
Seksyback
DC
This was what I was thinking too, as long as they align my tailgate and fix the other 2 trim pieces, I'll be a happy guy. Seen so many cybertrucks, seems like these panel imperfections are the norm.
Horizonvangogh
Everett
Oklahoma City, OK
Model 3
Owner of Future Detail
I will say the sail dimples pretty much go away when you wrap with satin and matte films. However gloss films make the dimples more noticeable from certain angles.
CA Boertjie
Jacob
2025 AWD Cybertruck, 2026 Model Y
Data Scientist
Picked up my AWD CT on Friday and LOVE it - already 400 miles driven!
Looking over it carefully though, the left side of the frunk is significantly lower than the right and misaligned to the body (see pic). The service center said they don't think it can be adjusted. Any suggestions - should I "refuse" it while still in the 10-day window?
Tesla Roadster 2nd gen Panel gaps and trim imperfections. 1740092733312-l
JCERRN
J
Around
Yeah
All you have to do to fix this is adjust the bump stop inside the frunk to be a little higher
