- Ace
- Jan 22, 2025
- Arizona
- 2024 foundation AWD, 2024 model x
- Trauma Surgeon
So off-road do you do 36psi even though it’s loaded up?I weighed my truck at a landscape supply business at no cost. As to how much pressure? I don't have any formula. Just don't exceed the maximum cold tire pressure specified by the manufacturer. Also, watch for uneven tire wear. Too much pressure for a given vehicle weight will tend to wear the center of the tread faster than the edges. I put 60 lbs in my tires (cold) when the truck is loaded up with gear, then monitor pressures as temperature and altitude changes. I carry a portable compressor to inflate my tires after airing them down for better off-road traction.
