Method MR707 18" wheels with KO3 tires installed
TwiztOG43
Las Vegas
Wheel and tire specs?
TwiztOG43
Las Vegas
MR707 - 18x9 139.7 18"
KO3 - LT275/70 R18
Any reason why you picked that tire size? Seems like the 18s from unplugged and Martian wheels fit 285/75/18 without any problems.
tmeyer3
Trevor
www.meyerwine.com
Computer Scientist, Vintner
Lots of reasons I can think of:
Any 18 will fit that tire size, or stock width, fine on the CT.
+18mm offset wheels can fit even 35"x12.5" with no issues.
The CT is designed for 18s, it's in their off-road handbook. So any 18 inch wheel will fit, just gotta watch weight rating.
Method is extremely reputable and absolutely top-notch, especially the 700 series bead grips he got.
Method is less than half the cost of CT-specific marketed wheels.
TwiztOG43
Las Vegas
I am well aware of Method wheels. Have Method 305s wrapped in KO2s on an LC100.
Tesla Roadster 2nd gen Method MR707 18" wheels with KO3 tires installed IMG_6702
I was just wondering if it was just personal preference or was there a reasoning to the tire size since it is very close to what some aftermarket wheel companies recommend.
Also in regards to FSD, I would assume the extra poke with lower offset might be an issue? Usually when turning corners, FSD cuts pretty close to the curbs with the stock wheels/tires.
tmeyer3
Trevor
www.meyerwine.com
Oh, you meant poke? I'm using 12.5" width and +18mm, so some poke, but I've never clipped a curb and I run FSD everywhere. Probably about 2k miles on this setup
IntoTheRain916
IntoTheRain916
Kai
Sacramento
Model Y, Cybertruck
Business Owner
That's actually one of the things I tested, and honestly, that inch and a half didn’t make much of a difference—it was pretty much the same.
TwiztOG43
Las Vegas
Great! Good to know!
ABILISK
DFW
ts.la
‘24 Beast
Referring to this page?
Tesla Roadster 2nd gen Method MR707 18" wheels with KO3 tires installed IMG_7401
