Mars Adventure Gear
San Francisco
Hello guys,
We'd like to introduce you to our latest product, the MARS™ Air Mattress – a comfortable sleeping solution designed for two people in your Cybertruck! The air mattress kit includes an electric air pump and can be stored away in under 20 seconds.
Use code EARLYBIRD to enjoy 10% off. Purchase Now
Follow Mars on Instagram, X, or Facebook or join the Mars Community on Discord to avoid missing the latest product announcements.
Tesla Cybertruck MARS™ AIR MATTRESS FOR CYBERTRUCK NOW READY TO SHIP (W/ ELECTRIC AIR PUMP) IMG_9861-Edit
  • Water-proof material that makes it easy to clean the surface - rinse it up and it will dry in seconds
  • the kit comes with an electric air pump that can inflate and deflate it in less than 20 seconds
  • the included electric air pump can be plugged in to the outlet in truck bed
  • fits the shape of truck bed perfectly - specifically developed for the Cybertruck truck bed.
Tesla Cybertruck MARS™ AIR MATTRESS FOR CYBERTRUCK NOW READY TO SHIP (W/ ELECTRIC AIR PUMP) IMG_9899-Edit
Mars Adventure Gear
Mars Adventure Gear
San Francisco
what does it look like rolled up/packed away? and how big is the air pump? if you can show it within the bed that might be helpful to show how much space it takes up
It's actually pretty small - when it's deflated all the way it's basically like a twin size blanket that can be folded easily. We will take some pictures for reference later! Thanks for the suggestion :)
Mars Adventure Gear
Mars Adventure Gear
San Francisco
Same question. I'm waiting for a nice thick custom sized airmattress!
wow thanks for the suggestion! When we custom designed these, we had the option to go with 3 inches or 5. We tested different thickness and figured 3 in was our favorite. We might consider increasing that in our next batch of production!
Mars Adventure Gear
Mars Adventure Gear
San Francisco
How thick is it? It appears to be 3 inches or less. That generally means that my butt will feel the ridges of the bed.
It's about 3 inches! The air mattress inflates to ~ 10 PSI and we can guarantee you your butt won't be touching the ridge :ROFLMAO:
WHIZZARD OF OZ
Ivan
VW Up!
Electric Wheelchair Builder
Hello guys,
Tesla Diner here we come!
Drive-in Drivin' Knights .....Perfection even for 'The Princess And The Pea'
PUMP IT UP!
WHIZZARD OF OZ
Ivan
VW Up!
Hello guys,
Just add 'Romance Mode' screen....FIRESIDE FIRESLIDE on the dividing back window. Projecting Idea!
GFleck
Greg
Indianapolis Indiana
2023 Model Y, 2024 AWD Cybertruck
3 is probably good for sleeping laid out all flat but we use truck a lot for the drive in and like a little thicker and cushyier for 3 or 4 relaxing, propped up at drive in. One Klein would be to just buy 2 but that's a bit pricy.
This is tricky to describe, but I'd absolutely love it if somebody made an inflatable back rest that was shaped to fill in the negative inclined back of the CT bed and give a reclined back to sit up and lay back against. Also for our drive in setup ? Basically a big four foot wide triangle.
Mars Adventure Gear
Mars Adventure Gear
San Francisco
That's great feedbacks, thank you so much! If you'd like to experiment with 2 mattress, DM us and we can throw a used second set for free. The only thing we asked is your feedbacks once you've used them (basically we want to know if 6 inches is indeed the right thickness :))
loki
localhost
Yes please let me know too! Drive in was a primary use case I was thinking of too
rlhamil
Richard
Glen Burnie, Maryland
2002 Trans Am WS6, 2018 Kia Sportage, 2024 Cyberbeast FS
Better than Astroturf for those er, special moments? :)
Bz22
Matt
ATL
F150
I’m interested. I second the thickness doubling up might be the way to go. Would a thicker mattress allow for increased psi? With temperature drops it would be nice to be able to inflate to a higher psi or have a thicker mattress.
