FSD's reading of speed limits might be a little off
deek
Glenn
Management
There is a section of highway not far from the tesla plant where the speedlimit is 85. The truck frequently reads it as 65.
JCERRN
Around
Yeah
There is a stretch of E-470 in Denver going north, where my CT thinks it's a speedway. Thank goodness FSD maxes out at 85.
Wtf.
“where were going, we dont need roads”
Tesla Roadster 2nd gen FSD's reading of speed limits might be a little off 1764994109774-e1
Reactions: AC5
TickTock
Phoenix, AZ
Electrical Engineer
I have to turn off FSD for US 60 in the Phoenix valley. Truck keeps going back and forth from thinking the speed limit is 65 mph to 60 mph and back every half mile. I wouldn't mind so much if I didn't think it would get me shot.
God bless Texas
Long ago, Mobileye held the patent for “computer reading of street signs via in-vehicle camera” or some such, and it was presumed that Tesla’s AP/FSD was forced to work around the problem. So they’ve mostly gotten a pass on this, and rely primarily on map data.
IDK if the patent still holds, but no one is gonna fully trust an autonomous vehicle that can’t distinguish between a sign that says “SPEED LIMIT” and a highway marker.
When all cars are autonomous no one will GAF but we’re a long way from there.
I know that human input is error yada yada but why the hell not crowd source this like Waze?
allow users to tap the speed limit sign in the FSD visualization and either enter a number or hit plus/minus. There are enough FSD users you’d quickly have an excellent scatter plot the fleet could use. Especially in more populated areas where it matters much more.
The user base is fairly devoted, how many of you are shouting into the void and leaving voice messages daily with FSD disengagements? I’m willing to bet a lot.
CG Cowboy
Dale
Lebanon, TN
www.cgcowboy.com
Cybertruck Foundation Series
I have a similar problem. It's taking every speed limit sign as THE sign.
Pass a normal speed limit sign : Set
Pass another immediately specific for trucks a little slower : Set again.
Then it will pass a Minimum speed limit and set again. Sometimes these are 25 mph creating a dangerous situation on the highway when in FSD.
Anyone else seeing this?
Patriot
Denver, CO
2020 M3, 2024 Jeep 392, 2024 FS CB
I have seen the 100MPH multiple times on E-470 as well. It didn't use to do that. It usually completely ignores the speed limit signs and seems to use map data instead. It would be nice to have insight into what it's doing sometimes.
DanK
Clare
Mojave Desert
AWD Cybertruck
Yes, southbound I-15 approaching Cajon Pass my CT set the correct 70 speed limit, then it set the speed to 45 (the truck speed limit) and then a mile down the pass it set the speed limit to 100. When most are going 75 and the CT set the speed to 45, was dangerous.
Gaximus
Mead, CO
Software Developer
My model S used GPS data for speed limits, it was obvious because it would know the speed as soon as it turned onto a road. But my cyber truck is reading the signs, because it changes as soon as it passes them. It can (sometimes) read construction signs to, and GPS data doesn’t have that, My model S would just speed through.
AC5
AC5
Andrew
Denver
2024 CT AWD, 2022 MYP
I noticed that as well. It seems that the latest update to FSD, either 14.2 or 14.2.1, added this 'feature'.
pae1andonly
Paul
2024 RAM 2500
Had multiple incidences of FSD reading the TRUCK speed limit as THE speed limit. Embarrassing pulling out aggressively sort of in front of someone in madmax mode only to then crest the next hill and slow down like gramps. :rolleyes:
Gigahorse
AWD
Tesla Roadster 2nd gen FSD's reading of speed limits might be a little off {filename}
With Tesla going ALL IN on camera only vehicle autonomy it concerns me when I drive by a sign that says 45MPH clear as day and the truck continues to barrel along at 60 (in chill mode)
