BeFamousVideo
- Vincent
- Feb 16, 2024
- Orange County, CA
- CT Beast delivered May 2024
- Automation Agency
The auto park feature hasn't been as accurate as a human in my experience. Parking is often more than 18" from the curb. In one instance backing into a covered car port the truck forgot about the mirrors and hit a pole with the passenger mirror, I was watching the drivers side since it was a tight spot, luckily no damage as I stopped before further damage happened.On Friday, I had the truck in fsd and was pulling into a supercharger. I heard rumors that it would find an empty spot automatically and that's what it seemed like it was doing so I let it keep going. It rammed the front into a grey post! I slammed the brake so the damage wasn't huge but it damaged the front fender and maybe a bit of the front camera. From the video it was clear that it was unable to see the pole. I wonder if this will happen to all cybertrucks at this super charger in Rochester WA.
I think I should be able to about out the plastic with a heat gun. Not sure about the camera which looks like the joint might be cracked, otherwise still works fine.
In your situation it seems like the truck should have seen the post being as it is tall enough for camera to pick up. Too bad this happened to you.
