Front console powered storage
CTOmaha
Nebraska
CT FS AWD, MY 24
I ordered this from Amazon
https://a.co/d/bbQAPnv
I like this better than others especially with the extra charging ports. And this is sold plastic so no more of dealing with it falling through.
It has a switch in the middle to turn on lights in high and low. Low is a bit more than what the CT already has and High is much brighter. The usb ports also have a little green light making it easy to spot.
And yes I did get a discount from Elecfresh via DM.
Tesla Roadster 2nd gen Front console powered storage IMG_0600
Tesla Roadster 2nd gen Front console powered storage IMG_0601
Tesla Roadster 2nd gen Front console powered storage IMG_0606
Tesla Roadster 2nd gen Front console powered storage IMG_0603
Tesla Roadster 2nd gen Front console powered storage IMG_0605
Tesla Roadster 2nd gen Front console powered storage IMG_0607
Tesla Roadster 2nd gen Front console powered storage IMG_0598
Foundation Series Dude
Terry
Atlanta
Foundation Series Cyberbeast
Entrepreneur
How does it power? Does it plug into an outlet inside the console?
Picture on Amazon appears to be one USB-C male end. It's kinda hard to tell from the pic but if you look at their Rear Seat charger hub, it has two USB-C male plugs that once you see them, looks like it's the same for the Console one.
Tesla Roadster 2nd gen Front console powered storage 1737320474852-sn
CapheDa
Dustin
Brea, California
2018 M3, 2023 M3P, 2024 CTFS
Investor
I like it! The USB-c in the box provides enough power for all those usb outlets and the light? That’s great. If someone DMs me a code, I might just order one. I’m sick of my rubber tray falling through when apply the slightest pressure.
devdrone6
Dev
Nebraska
Cybertruck, 2023 Model Y
Yes, that cord plugs into the console and it supplies the light and ports. Good question on it solely providing power for all those ports, wonder what the Amps are.
CTOmaha
CTOmaha
Nebraska
CT FS AWD, MY 24
DM Elecfresh on this site, and mention this Thread ?
Casper
Casper
Ohio
Model x, Cyber Beast, Jeep Grand Cherokee, C177 ;)
Pilot
ordered today - seven days to deliver. i got the back seat too.
L3it3R
Chris
Maryland
Pretty sure the USB-C ports in the truck are all PD60 (I use them to charge my 16” MacBook Pro M1 Max and to run my Starlink Mini) , I seriously doubt the ports on this accessory take advantage of that, but if you’re just looking for more places to plug in, I suppose this is worth the drop for a couple devices.
I also keep a 110 wall plug multi charger with usbc pd100 and a few other ports which I got from Bestbuy in the center console for when I need to plug in many things at the same time
rudedawg78
Ernie
South Carolina
Hi there,
Unless I am doing something wrong, my Starlink mini can not be powered by my USB-C ports. I bought the cable from Starlink and spent hours trying to get it powered from the UB-C ports. I contacted Starlink and they told me that unless my USB-C ports can supply 100w, then it will not work. When I use the regular AC plug for my Starlink, it powers up perfectly. But, no matter where I plug in my starlink USB-C plug, it will not power up.
Am I doing something wrong?
L3it3R
Chris
Maryland
Hi there,
You’re using the Starlink USB C cable which indeed does require pd100, I simply ordered a barrel jack to pd60 usb c adapter from Amazon and it works perfectly ?
rudedawg78
Ernie
South Carolina
Ahhh, I see. Good to know! Thanks.
Cactusrick
Richard
AZ
CyberBeast, MYLR, EXT, 380SL
retired invest
I've got one ordered ... should be a great improvement!
CTOmaha
CTOmaha
Nebraska
CT FS AWD, MY 24
Wanted to update on this accessory- it stopped working all of sudden a few weeks back. Elecfresh is no longer a sponsor on this site, they are banned 🤔
Anyways, I contacted them through Amazon and they sent me a replacement right away. I did not expect that at all, I figured they would tell me to go pound sand. But I just got the new one- have to give kudos to them 👏.
