Fixes for sheared light bar roof bolt?
Derektsla
Derek
Greenville, SC
Cybertruck AWD, Model X
Entrepreneur
So this happened today while installing the T-Sportline light bar. I didn’t even crank it down. These appear to be cheap cast bolts that are NOT easy to replace. (Thanks Tesla ?). Nearest service center is 2 hours from me.
The bolt sheared flush to the bracket. Any ideas on a temporary fix for a while?
Tesla Roadster 2nd gen Fixes for sheared light bar roof bolt? IMG_3850
aeroguy
VA
Are those spot welded studs like the bolts over the bed? As a temp repair, you could grind down the rest of the stud, drill a hole, and bolt through? Not sure if the underside is accessible if you take off the cantrail.
Lowcoe
Erich
S3xY
Gardner
I kinda worried about that. Doesn’t make me feel great about strapping more than a couple 2x4’s to a roof rack…
Gogster2k
Gogian
Montebello, CA.
Dodge Charger, Honda Odyssey, Tesla M3, MY.
Retired. Tier II Desktop Support Tech, Southern California Edison
If you have or know someone who has a Drexel tool with a grinder disk attachment, you can carefully grind a slot on top of the sheared bolt and use a big screwdriver to remove to broken stud.
