CTMike
- Mike
- Jun 13, 2024
- Cocoa Beach
- Cybertruck FS
I had the same problem as everyone else until I stumbled onto the solution. Each side piece with the 2 pads can actually move in and out just a little. So, line up the pads to the holes and pull the end pieces out towards the L track just enough where the pads are touching the holes. When you get both sides touching the holes, then press down on the center lever, which will then push the pads all the way into the holes. Now they are locked in.Thanks for this tip. Gonna check now!
