Cybertruck sunscreen install tips
3PinkyToes
Paul
Colorado Springs
Cybertruck Foundation AWD
If you look at the sunscreen you will see a small tag at one corner. When you install the sunscreen have that tag facing down so you can see it. It will also need to be on the driver side front corner and it will fit like a charm. I recommend using the extra tabs to have 2 tabs per side.
Thank you for attending my TED talk
A-AY-RON
TX/VA
SYSTEMS ENGINEER
Correct. Once you know the CT silhouette tag faces the same direction as the truck, it can only install one way.
