One imagines the trailer would also have a motor if it had batteries for regen braking and motoring.Personally, I donāt think they are going to put batteries in the trailer. Mainly because that would suck up a bunch of batteries that could be used to make more cybertrucks. But if this battery technology they are planning on releasing in April is as good as it is rumored to be, there might not be any need for more batteries! And also, those batteries would add a lot of extra weight, making the electric motors work harder and use more power.
True, however that would continue to add loads of weight and cost! the cost of a trailer loaded with batteries like that would be pretty extreme. probably even more than the cost of the truck. All in all, batteries in the trailer probably isnāt viable, but they could do solar on top of the trailer to get some extra miles out of it, especially with giga NY pumping out solar tech.One imagines the trailer would also have a motor if it had batteries for regen braking and motoring.
I also hope battery day is amazing. But cybertruck is shown with a Tesla trailer which implies Tesla will make a trailer and the additional price of the batteries will quickly be recovered by the lower cost of electricity vs fuel.True, however that would continue to add loads of weight and cost! the cost of a trailer loaded with batteries like that would be pretty extreme. probably even more than the cost of the truck. All in all, batteries in the trailer probably isnāt viable, but they could do solar on top of the trailer to get some extra miles out of it, especially with giga NY pumping out solar tech.
Me too! I don't really think they would put batteries in the trailer either way, but in some renders, we have seen an RV trailer. I would put money on them attaching a battery pack to that, seeing as you could power internal appliances and outlets without drawing from the cybertruck. And solar on top to recharge that battery pack. However, you would probably have to charge that large trailer at a Megacharger, because it just wouldn't fit at a regular supercharger, and rather than disconnecting the cybertruck and charging that separately, the trailer and the truck could be charged with one plug on the trailer!I also hope the battery day is amazing. But cybertruck is shown with a Tesla trailer which implies Tesla will make a trailer and the additional price of the batteries will quickly be recovered by the lower cost of electricity vs fuel.
Thanks, i figured someone had thought of this. Seems like a good idea if going on a camping trip with no charging units.I think it is possible for the trailer to have its own motors and it's own battery. This is not something new. There is already out there a trailer concept that has that capability and it does for the trailer to be parked by itself using an app. The additional benefit of having a trailer that would assist pulling it with the Cybertruck, means that the truck will need less effort and less battery consumption to be driven with the trailer. So, in the end you could theoretically have an extended driving range while using the trailer. Also, if you consider that there will be lots of space to add solar panels, in theory, you could have a combined system that will allow you of the grid living for 4 days, or so.
I can easily envision this, each module is approximately 1/3 the width of the bed, locks down to the slots in the floor. So you can mount one in the middle (with atv wheels or motorcycles on either side), or maybe even two on either side with the middle left open (say for a 5th wheel?), or all three for max range.IDK about a trailer... As others have said - more weight, more wheels, potential brakes and suspension, and one can't haul a grant load for business if one also needs to haul a battery trailer...
What I'd prefer to see - a battery pack that takes two persons to lift, sides into the back of the CT truck, and has "daisy chain" connections for power and cooling transfer.
This would mean that a person or business could purchase between one and (maybe, depending on size) four battery packs as needed for additional power. They would charge along with the CT and when driving the CT cooling system would keep them cool as well.
I think this, if implemented, would be a game changer for business use applications for the CT!
Most fluid systems have a bubble purge integrated. So, the CT system likely already has this and within a few minutes the entire system would be purged. Um... But, now that I think about it my opinion is based on really old tech. Maybe, not with new tech?I can easily envision this, each module is approximately 1/3 the width of the bed, locks down to the slots in the floor. So you can mount one in the middle (with atv wheels or motorcycles on either side), or maybe even two on either side with the middle left open (say for a 5th wheel?), or all three for max range.
Maybe even make them so they can be stacked?
Daisy chained and with coolant, there are some expensive connectors that allow lines to be kept full, but there would still be air bubbles added everytime you connect... That will need some kind of automated purging system... which adds expense and weight.
Maybe their no-spill connectors? Not sure. https://www.boydcorp.com/resources/...ogies/fluid-coupling-connector-selection.html
Having done some work with medium and high pressure hydraulic systems, I wish they had bubble purge systems in them, because purging air bubbles from the system was messy and not easy.Most fluid systems have a bubble purge integrated. So, the CT system likely already has this and within a few minutes the entire system would be purged. Um... But, now that I think about it my opinion is based on really old tech. Maybe, not with new tech?
I was, actually thinking the packs would run side to side. This way when the first pack was slid to meet the cab the center of gravity would remain center to the truck. Then, additional packs would slide forward. 3-4 packs and they would create a new bed floor raised up by a bit more than one level of batteries.
But, your idea of the pack running front to rear is great as well for a versatile load and ease of use with a fifth wheel.... I like it.
Yeah.... Might not be with it for a 500 mile tri-motor. But, could really be worth it for the lower range models.Having done some work with medium and high pressure hydraulic systems, I wish they had bubble purge systems in them, because purging air bubbles from the system was messy and not easy.
I did it so the additional weight would be centered over the rear axel. If there was too much hanging out over the rear axel, just would need to make it shorter... also, if being able to be loaded by two people, weight would need to be 72 to 148 lbs. Coolant will be a significant weight, so energy density and weight will be key for these.
Model 3's battery pack is about 1054 lbs and is composed of 4 modules, which means each module is ~18 kWh each at roughly 250 lbs. Supposedly the technology from battery day will allow them to reduce weight by 69%. Give some allowance for case, coolant, and connectors, call it 150 lbs for the bed pack and have 18kWh each. Putting 3 in would be 54kWh and 450 lbs (plus cable/hose combos).
The new cells are 80 mm, which is just over 3 inches. Double that for case and cooling, call it 6.5 inches (165mm) raise to the bed height. If they are just smaller versions of the pack in the truck, they would be structural and be able to take a load. This would be a 20 to 25% increase in the battery pack. Call it 600+ total miles (from the 500 original for the tri motor).
Definitely some will think it is worth it, but will Tesla?
I would just be happy to hear that CT comes factory-equipped with AUX power connector.Has anyone heard of a tesla trailer for CT with additional battery pack built in? I tried tweeting Elon but no reply.
