Brake Caliper / Pad Removal Issue
CyberNickOH
Nick
Powell, OH
2024 Tesla CT AWD FS
Decided to paint my brake calipers, which I’ve done a few other times and pretty straight forward. Have also replaced many pads over the years. 2 issues with the CT.
First was removing the front driver and as I’m working the pads out, both pistons were basically glued to the pads and popped out. Seals and pistons look fine, and hopefully reseat them and then go thru a pain the ass fill and bleed. The other front was fine. Anything else to watch out for putting it back together? I guess now I can just remove all the brake lines and make painting them easier.
Second is that both rears will not release, whole assembly will not come off. I followed the service manual and turned off the MV, disconnected the rear EPB, but I don’t think it’s actually released. Parking brake is not active, but it was while I jacked it up. Any ideas?
CyberNickOH
CyberNickOH
Nick
Powell, OH
All right, got the EPB to release. Hooked the power back up and turned on the 48v, was able to get it into towing mode.
Just hope I don’t need to build the caliper seals. Why are easy projects never easy with EVs? Love it though, learning a lot.
ABILISK
DFW
ts.la
‘24 Beast
Wish you luck. I have no experience whatsoever in this area. I’m pretty competent with tools but I’ve never even changed my own brake pads lol
