Boat towing with Cybertruck was great experience
Ken in Miami
Ken
Miami, Fl.
2024 Foundation series
Real Estate/ Agriculture
This was a great experience. I was worried about the ramp more than the road. But the truck performed better than expected on both.
Is that Black point marina? Trees look like main parking lot.
Ken in Miami
Ken
Miami, Fl.
Yep, that is Black Point Marina on Tuesday. Had to try on a day that was not busy.
I use to keep a boat on B dock and have used those ramps for over 50 years. Now I keep my boat mostly on the west coast. Black point became famous due to that u tuber! I saw at least six Tesla trucks yesterday in Coral Gables and when I pulled into MIA terminal I was flanked by the darkest black one I’ve ever seen it was so deep of a black it disappeared! Tomorrow when I go for dinner I will be joined by two whipper snapper techie relatives that both have shiny black ones. They are everywhere now and most I see are black or deep brown. Was the boat easy to back on that ramp? Low tide can be rough there!
js-cybertruck
js-cybertruck
Miami Fl
It took me two tries to get the correct position. Traded in a German tank GLE350 for American Heavy Metal.
I am thinking about a wrap…so many choices. I will stay with SS for now.
Ken in Miami
Ken
Miami, Fl.
On two tries that was good! I found it easy to just use my Hummer and open the lift gate so I can see easily like when using a pick up truck to back up into a tight place like a ramp. I will try it in December with the Tesla trucks
Did you have truck in high suspension when backing down that ramp? Does it tow your boat (23’) ok?
countryboy
East TN
M3P | CT FS AWD
Did you not get the warning incline too steep, parking brake may not hold with trailer?
My only complaint about CT really, have to carry a wheel chock for when I launch solo so the whole kaboodle doesn’t end up in the lake. In my ice trucks they had transmission interlock or 1st gear manual to help the parking brake, no such thing on CT :(
I’m hoping they come out with software fix that will leave it on brake hold when you get out, to fix this and when stopping in a steep area rock crawling to get out and look at the best line. Actually had it roll back 10’ unexpectedly on the trail, lucky didn’t go off the edge, which is why the boat thing worries me, even tho it hasn’t actually slipped, just the warning, which is not confidence inspiring.
  • Wow
Ken in Miami
Ken
Miami, Fl.
Holy Crap! 10’ back I guess lesson learned will be leave window down in case you have to jump in! Black Point is famous in you tube videos for people launching their boat and truck into the salt water! Do not want to be famous for first launch of an electric truck into ocean but it’s guaranteed if you do it at Black Point you will be famous! I like the chalk idea so you do not lose ground.
Better to use chock anyway, as it could easily save your life.
countryboy
East TN
M3P | CT FS AWD
This is not a fire truck. In 30 years of towing never had to chock on the ramp, or off-road. The risk is once you get out to place the chock, you have to trust the parking brake for those few seconds. That’s more dangerous than having brakes that actually work.
If your vehicle is telling you that the incline you are currently on 'may' not hold with the parking brake, then it seems reasonable to use a chock. But to each his own ?‍♂
Keeney
Rick
Minnesota
F150 Lightning Pro
So the CT does not have an actual mechanical parking mechanism in its transmission?
So Ford got another pickup truck thing right and Tesla skipped it?
In the Munro video where they tear down the Lightning motor/axle/differential, they make a big deal about how Ford told them a true parking pawl is needed when parking on hills with a heavy trailer.
Jet55
Ron
Northbrook
Ram TRX with Cybertruck on order
I sell boats and am a boater myself. I frequently have something hooked to the back. Heaviest load was my Crevalle 33 and that was pushing it weight wise. Overall the Ct tows great but kind of sucks backing down a ramp due to visibility. I found my Rams much easier.
countryboy
East TN
M3P | CT FS AWD
I already said I was using the chock. But that means walking from the driver seat to the chock and then to the wheel without anything holding it. How would you solve this? A software update to keep brakes on just like it does at every stop light after I get out of the seat would be nice right? :-/
Get a wheel chock with an eyelet, attach nylon rope (15/25 feet should do). Set the chock on the ramp where your wheels would straddle it, back up to your stopping point while holding the rope with the window down, then pull the chock until it's under your driver side wheel. Should be able to see it out the window (door open is more risk, of course).
Give that a try ?
