bongaarts
- bongaarts
- Feb 1, 2022
- UK
- toyota v8
- freelancer
So still troubleshooting (using INPA)
The car is not being used regularly but has not had any problems
recently the charge on INPA for last week has been in the 40%-60%
I had a battery discharge alert as well, which goes when I drive
I had an alarm which basically translates to;the car is not going into sleep mode or rather keep going awake after sleep mode (forget the code)
so there is a drain.
My comfort access handles have not been working for a while, so I also heard this could be causing a drain , though no alarms for the CA system
Another thing I heard was if the battery is having problems, it switches of things in order to save power, wondering if the CA is shut down fo this reason, first passengers stopped then drivers stopped.
Battery is about 4-5 years old? It was replaced by a dealer when I bought the car, about 4-5 years ago
Thanks
I was thinking of pulling the CA cables to see if that resolves it not sure though, thanks
Thanks
