countryboy
- Jan 25, 2024
- East TN
- M3P | CT FS AWD
I started working on this a while ago as an alternative to nut caps, but someone else beat me to it because I didn't have a truck to test on. After a few days playing around, here is my current missing wheel covers solution. Created in Tinkercad using a simple heptagon cone so the edge is tapered like the wheel. Still tweaking the attachment design (printing v0.7 test right now) but the look won't change much. Made on Prusa MK4 using generic 90 hardness black TPU, so it's flexible but not floppy. Not sure how it will hold up to UV, but easy to make another one. The small triangle pattern is from the build plate and the big 7 triangles are from concentric extrusion, both change with movement but the small ones are very subtle. The seam line visible in the middle of one big triangle has been removed in latest version. I also tried silver TPU for the contrast look, matches the HFS pretty well, but a bit too "Raiders" for me, going to stick with black.
