Adjusting Speed in FSD? Scroll wheel doesn't work.
WydahoDan
Dan
Wyoming
2024 CyberTruck
Hello: When I'm in FSD, the owner's manual says you can increase or decrease speed with the right scroll wheel. However, nothing happens when I use the scroll wheel. Are others having the same issue (i.e., is it a software issue)? My scroll wheel worked before FSD to adjust cruise control speed. I live 4 hours from nearest TSLA service center so hopefully this can be fixed with software upgrade.
KevD0g
Mars
electric
Go to Autopilot settings and unselect "automatic set speed offset". This will allow you to manually set the speed offset and you will be able to increase or decrease speed from the steering wheel control.
WydahoDan
Dan
Wyoming
2024 CyberTruck
Thank you! If only the owner's manual made this clear.
Rvp.770
Robert
Mechanical technician
Had the same problem. Thanks.
ASSO is a relatively new feature. I suspect that there may be a lot of work around the feature as time moves on.
ewkplymi
Plymouth, MI
Ioniq5, Prius Prime, Cybertruck on order
Glad you posed the question. Going out right now to change the setting.
Kensei
Tom
Socal
Even with I have it on manual max speed control, FSD rarely hits the speed limit. It's usually under by 1 or 2 mph. On my other Teslas on AP, I can set it to +5 and it holds it fine.
cardad
Kelvin
Moab
R1S, R1T, Bronco Raptor
This feature still requires manual acceleration to the target speed at times. The current tendency is for the vehicle to remain below the target speed limit.
Jayse
Jayse
Las Vegas, NV
Cybertruck Foundation, Model 3
Designer
Yeah I just put the pedal down to speed it up where necessary. Then it drives at the right speed. Works great!
mitochondria
Matt
North Idaho
DM CT, S Plaid
I try accelerating and my beast slows down every time! Can’t wait for 12.5.5.2 to hit. Hopefully it fixes it.
Kensei
Tom
Socal
That's annoying EAP worked great. Wish there was a way to toggle AP then double press for FSD.
It should bring it up to speed and stay there until the next curve in which it resets.
I do it all the time.
