Powering Accessories Struggles - Don't let this happen to you!
Rippin1Gear
MJ
Seattle, WA
Foundation Cybertruck
plumber
Thank you all for the great research and documentation in this thread! I purchased the Hansshow v2 mirror during their Black Friday sale and have been too busy to install it. I'm wondering now if I should return it for a competitor's product, or live without a full speaker complement in the meantime...
You could email them and ask when the new updated harness will be available to see what reply you get.
carsly
Vin
Princeton, NJ
LR Defender, CT AWD
I guess I'm down a speaker since I'm running the latest Hansshow rearview mirror. Should they have a harness with passthrough power? Absolutely.
...but here's the thing, I don't notice the missing speaker but absolutely notice, and use, the review mirror camera. It's a more natural, and I'd argue safer, way to operate.
I’ve completed a 12V DC supply solution that works for me.
I routed a 12VDC supply line to the passenger foot well for the Hansshow V2 mirror and one behind the screen for a radar detector.
Works perfectly with “Enable Cabin Outlets on Entry ” selected. The power comes on when you enter the vehicle and goes off when you exit.
Fairly easy project that solves the 12V DC supply issue. Front console panel pops off easy to give you access to run a line to the 120VAC outlet. Note that the power to the outlet is available, orange wires, but I didn’t want to mess with splicing those and found a nice pass through outlet that works fine. The console bin is made of a soft rubber but I still added a grommet to make it look neat running from the outlet.
I moved the radar detector from a mirror mount to just above the screen. This doesn’t obstruct the view out the windscreen at all. I posted the link to the mount I used.
I cut the Hansshow harness off and spliced the USB-C power lines to the 12VDC supply line. In the event I add anything new I have a small 4 line fuse box I can add here for future upgrades.
Parts for reference:
Pass through outlet: Cable Matters 2-Pack 2 Outlet... https://www.amazon.com/dp/B09DMRWYX8?ref=ppx_pop_mob_ap_share
12 VDC Supply: LED Driver 12V 100W 8.3A Slim LED... https://www.amazon.com/dp/B0CWWM7DS5?ref=ppx_pop_mob_ap_share
Radar Mount: Bartallama3D Radar Holder for... https://www.amazon.com/dp/B0DJZYF7XX?ref=ppx_pop_mob_ap_share
Very nice work. Could you show with a marking of some sort where the pass through outlet is? Where did you wire the AC side of the converter? Also, what drove the choice for that specific convertor over the 300-400w ones? Size?
TeslaKen
TeslaKen
Ken
Overland Park
www.halocybertruck.com
Currently Occupied
I've reviewed this and first thing to say is "Good Job" in finding a solution that works for you. Looking at how you've created this my biggest question is getting power from the center console down below where the convertor is to the passenger footwell where the harnesses are for various items needing 12v power such as front bumper light bar, rear view mirror display, LED dash light strip and I guess in your case the radar detector?
The 2nd question I have is if you have the line going to the Hansshow rear view mirror can you show which line you cut and where you tapped it in? I would need similar for the LED light harness, 2nd screen harness and front light bar harness if I were to attempt to move them all over to the power feed from the center console, assuming of course that feed is run over to the passenger footwell where all the connectors/harnesses are.
As for radar detector mine has a GPS in it and I find that it needs a good clear view of the sky so I have it mounted below where my tinted area of the front window is otherwise the tint blocks the GPS signals. I cannot mount it on the top of my main screen like you did, but I think it is great that you can mount yours there.
YukonJack
Greenville, SC
‘06 Tacoma, '24 CyberBeast
Where to cut the Hansshow harness: Follow the USB-C plug down past the small box (12V to 5V Converter) and you will see they have the wires already labeled. Three wires are loose and unbundled near the end. Cut and Tie both the ACC(yellow)and Power(red) together - twist those together and use a butt splice crimp to tie that to the 12VDC positive. Tie the GND(black) wire to ground. I ran two sets of 12VDC supply lines from the converter - both wrapped in felt tape to match the other harnesses. The pass through spot I used is outlined in the red circle. There is just enough room here to pass the wire through neatly.
There is enough room to run the wire up the center divider. You can tuck it in under the plastic molding then run it up under the rug to the right foot well. I spliced the Hansshow mirror at the footwell location like it was originally intended.
I bought this 100W supply a while back after I believe EVDave posted it in one of his videos. 8 Amps is plenty but there is plenty of room if you needed to go larger.
As an FYI I did find in the schematics reference to 12V DC Power. The MOC outputs power for the Radio tuner. Not sure how much excess capacity there is and didn’t wan’t to cut into any harnesses. Maybe Hansshow will read this and find a better place to tap. But you can look at X-2408-1 (VCC Power) and X-2408-4 (Ground). Also at X-0806-1 (12V Power) and X-0806-2 (Ground).
Tesla Cybertruck Powering Accessories Struggles - Don't let this happen to you! DSd_vlYvRee27ndGEb1b7g
This is brilliant Jack. I’m just not fully understanding where the wires going into the 120v side of that convertor are coming from.
Chopped off pass through power cord in the first photo:
Thanks. Was thinking of maybe reproducing this with the input plug of this thing I have plugged up to the center console 120v socket
Tesla Cybertruck Powering Accessories Struggles - Don't let this happen to you! IMG_9806
Basically I’d put a y connector on that plug and use one of those slim power supplies Jack linked to run everything I need to be on only while I’m in the car. Use “turn outlets on with entry” So the mirror, the starlights, the electrochromic thing on the roof glass, the baby cam and baby monitor. Maybe a radar detector eventually.
The stuff I want continuously running which is the fridge and Starlink, I’ll leave on my frunk power feed and auxbeam.
Key advantage being that the Tesla wiring can return to bone stock without mad science experiments à la teslaken. I still have a tweeter issue because of that nonsense and who knows what other gremlins will come up in the future that Tesla won’t fix because of aftermarket parts.
If I ever have a service issue and they try to blame it on the mirror with this proposed setup, I can just say, “what mirror? The one I just unplugged from the center console? “
They GAVE us both DC and AC options that can support about 400w each and yet we’re all still treating this thing like chinsey Mazda wiring for the sake of accessories.
the more I think about it the more I think it’s not smart to use cheap poorly thought out Chinese wiring harnesses in the middle of our $100k Tesla wiring.
Thank you again @YukonJack for helping me see that clearly.
@mongo , is there a simpler solution you can think of?
TeslaKen
TeslaKen
Ken
Overland Park
Currently Occupied
Thank you. Yes I saw where you tapped through to get the plug into the center console and then the wires coming from the plug to the convertor, I was more wondering about the wires coming from the convertor to the rear view mirror and/or other accessories. I suspected that perhaps you ran in under the plastic in front of the center console then up under the dash and over to the passenger footwell. With respect to the Hansshow harness once you cut the wires and attached them to the wires coming from the convertor, was there any need for the Hansshow harness anymore or did you pitch it? I was thinking of running the 12v DC power from the convertor to the footwell and attaching it to some sort of distribution block with black and red pins that I could then attach whatever accessories I wanted there assuming I don't go above 100w which I believe to be unlikely with these electronic devices we are discussing.
Such a shame that Tesla didn't think to have some 12v DC power adapter plugs in various locations in the truck to support non 48v accessories. Extra cost I guess but I don't see the automotive accessory market moving to 48v any time soon...
If you have any pics of where you tapped in at the passenger footwell or any routing pics please feel free to share those as well. Thanks again!
Yeah. That would have been super helpful Ken. I agree
TeslaKen
TeslaKen
Ken
Overland Park
Currently Occupied
This is a great work around. Any chance for a video?
If I do this install as well I will shoot video and write up an article. I guess I need to start by ordering the parts. :)
So in the case of my s92 the power comes from the FSD camera box but the on signal comes from the passenger footwell. Wonder if it will work with both routed to the convertor
Russell
Illinois
2025 Cybertruck
IT Sales
Similar issues here. Have the Hansshow rearview mirror cam/dashcam latest version and a 10.88" dashboard display which all seem to be identical regardless of supplying vendor. Neither one will pass power so whichever is plugged in first in sequence works, the other gets no power.
That's funny. Both Hansshow and Teslasy told me they had the other device (mirror or dashscreen) and if I wanted to buy their version "it would work". Obviously, I am passed it because I figured out a solution that worked and truthfully, after running the wires I don't feel like messing with it again.
Russell
Illinois
2025 Cybertruck
IT Sales
The fix here is Hannshow providing a harness with the pass through for pin 8.
Sometimes the deeper you go with Grok, or other AI, the more validation you need to do.
But I asked about other reliable power sources an it spit out:
Passenger Kick Panel / Footwell Area (Non-X0930 Sources): Some dashcam and accessory installs use separate taps in the passenger kick panel (near but not on X0930) for ~12V switched power. Exact pins vary, but owners report success without tweeter issues. Test with a multimeter for switched 12-15V on nearby harnesses.
Then when I tried to clarify I get:
Passenger Kick Panel Power Alternatives (Cybertruck-Specific)
The passenger-side kick panel (lower footwell trim near the door) in the Cybertruck doesn't have a traditional fuse box like older Teslas (the truck uses electronic fuses/breakers instead). There's also no widely documented "easy" 12-15V switched or constant tap directly in that area outside of the X0930M-6 connector (which you're already avoiding due to the A2B audio issues). Most owners report that probing nearby harnesses in the kick panel yields limited or no suitable low-voltage (12-24V) sources without risking errors or interruptions to other systems.
That said, here are the practical alternatives discussed and used by Cybertruck owners for ~12-15V power (suitable for your Hansshow mirror's 12-24V transformer input), focusing on cleaner/safer options:
1. Rearview Mirror / Autopilot Camera Housing (Upper Windshield) – Most Popular for Overhead Accessories
  • This is the go-to spot for radar detectors, dashcams, and digital rearview mirrors.
    • There's a 2-pin connector (red + black wires) inside the autopilot pod/cover behind the rearview mirror that provides ~12-15.5V switched power (active when the truck is on/awake, turns off in sleep mode).
    • Voltage: Typically 12-15V (some measure up to 15.5V), perfect match for your transformer's range.
    • How to access: Remove the mirror (twist/off) and pop open the black plastic autopilot housing (clips/pry gently – follow YouTube videos like Everyday Chris or Rick Zoerb).
    • Tapping method: Use a "mirror tap" kit (e.g., Escort/BlendMount style with flat blades) or custom T-harness (parts from DigiKey for pass-through). Many owners add a step-down if needed, but your Hansshow transformer handles it directly.
    • Pros: Clean routing (hide wires in headliner), switched behavior matches accessory needs (powers off with truck for proper shutdown).
    • Cons: Requires careful disassembly; low amp draw recommended (~1-2A safe).
    • Commonly used for Hansshow/Yeslak/Pormido mirrors and radar detectors without audio/tweeter issues.
2. 120V Cabin Outlets + 120V-to-12V Converter (No Wiring Needed)
  • Plug a compact 120V AC to 12V DC converter(cigarette lighter style, 10-20A rated) into one of the cabin 120V outlets:
    • Rear console (behind center screen) – most convenient.
      • Under rear screen or bed outlets.
    • Then route a 12V cable (or USB-C if your mirror supports) up the A-pillar/headliner to the mirror.
    • Voltage output: Stable 12-13.8V, high amperage available.
    • Examples: Owners use Anker/Similar converters hidden under seats or in console; some add multi-port strips.
    • Pros: Zero splicing/tapping, reversible, high power, outlets stay on appropriately (switched with vehicle state).
    • Cons: Slight bulk (hide the converter), but very reliable for mirrors/dashcams.
    • Bonus: Outlets power off cleanly with the truck, helping with your shutdown issues.
3. Other Nearby/Alternative Spots (Less Common in Kick Panel)
  • No confirmed 12V purple wire or similar (like Model Y) in Cybertruck kick panel – owners probing there often hit 48V lines or nothing usable.
    • Trailer hitch harness (if equipped): Some tap the 7-pin for constant ~12V, but it's rear-located and may not sleep properly.
    • Avoid 48V taps (frunk/roof) unless using a buck converter – not ideal for low-draw mirror.
I was considering the first option too and decided on your second option. I saw several threads where people using the power overhead ran into interference problems related to FSD, etc. I decided I didn't want to take the risk with anything like that.
