CybrCuk
How long did the FDU take to replace? Iām concerned about bringing it in because mine was in service for 2 weeks to replace a steering wheel module that was clicking because they couldnāt get the car to communicate with the new hardware until several escalations.Long time lurker. I had the same issue - static like / mild grinding noise between 40 - 50, disappears when going around a curve. Have an AWD VIN 53xxx, purchased as inventory in June and the noise started around September.
Took it in and they first replaced a window seal and bearings. Picked it up and driving away immediately heard the noise. Turned around and brought it back. Tech rode along this time and verified the noise and said it was not normal.
They replaced the Front Drive Unit - part 1930000-TX-F (Revision F) and the noise is gone.
Waited a bit to post to make sure the noise didnāt reappear. Its been a week and have put ~500 miles on it since. Noise hasnāt returned.
I know the FDU swap didnāt help for some but in my case the noise is gone, at least for now.
