Winching...
parapyropig
Thomas
2011 FJ Cruiser NSSE, Cybertruck trimotor
parapyropig
With a gross vehicle weight estimated to be in the neighborhood of 8000 pounds, you’d need upwards of a 15,000 - 16,000 pound winch.
My other thoughts/concerns would be how to mount one on the front; would it be able to be mounted semi internally (not to mention be able to be wired), or would it have to be mounted in an external bumper like other conventional 4 x 4‘s.
The lack of hard data and specifications available at this point is testing my patience. ?
Ehninger1212
Jake
Houston, TX
Architect/Fabricator
My hope is in the frunk. Winch is protected and does not interfere with the aerodynamics. It would be really sweet if there was a winch plate already in the frunk.
I like this idea! Only concern would be how the cable comes out? ?
UpToNoGood
Steve
New Mexico
2018 Tacoma 4x4, 2015 Super Tenere
Cyber stuff
Replacement bumper in the front with a 2" receiver tube. Get a winch that comes in a cradle. Wire both front and back of the truck. Pin the winch cradle in either front or back depending on the direction you need to be winched out. When done put the winch back in the Frunk. This solution keeps the winch out of the weather and doesn't change the front end very much. Also allows for both direction winching.
parapyropig
parapyropig
Thomas
parapyropig
It’s easy to wire a winch into a conventional vehicle. I wouldn’t know the first thing about wiring in to the TCT.
Fingers crossed that Elon takes these things into account.
UpToNoGood
Steve
New Mexico
Cyber stuff
Elon could save us all the trouble by offering the front bumper with a built in 2" receiver tube and wire both the front and back for the winch as an option.
Ehninger1212
Jake
Houston, TX
So far Tesla has had a conventional 12v battery in there vehicles. It would wire up the same way as any other.
Otherwise we can wire it to the main battery and make it super fast!! ? Plaid mode winch!!
Ordinaryguy
Peter
Canada
2018 4 Runner Offroad
Yeah, that sounds good, but big winches are heavy, and lugging a 80 Lb winch around and sliding it into a 2" receiver isnt for everyone, UpToKnowGood. It would be easy to allow for a winch driven by a PTO, to minimize weight. PTO driven winches are stronger than the bumper winches powered by a small electric motor. A more elegant solution for a vehicle like the Cybertruck, if the designers are on the ball and want it to have off road capability.
Ehninger1212
Jake
Houston, TX
So, on an ALL ELECTRIC vehicle.. you don't expect an electric motor to drive the winch?
Ordinaryguy
Peter
Canada
Haha, not at all just driven by the vehicle not by a Mickey Mouse winch motor made in China.
Ehninger1212
Jake
Houston, TX
I think that would WAY over complicated things.. So now your talking about disconnecting the motors from the drive unit so they can spin an independent Shaft that runs to the winch?. Even if your talking about a Hydraulic PTO.. that is still way over complicated.
Lets be honest.. how many PTO winches do you actually see around anymore being installed on new vehicles??
Oh and yeah.. Tesla producing parts in CHINA!?!? that will never happen... ?
ajdelange
A. J.
Virginia/Quebec
EE (Retired)
It's not conventional in the sense that it is tiny - does not have to operate a starting motor. I would think a winch would need a higher capacity battery.
But then we wonder whether the CT will have a battery. Why not a DC/DC converter or...
The current cars have a high voltage compressor motor in the HVAC/cooling system. That's the only other high voltage motor I am aware of (other than the traction motors, of course). I'm guessing that they will try to avoid doing this out of the desire to avoid 400 V wiring. Be interesting to see what they actually wind up doing as I think a winch is definitely something buyers will want.
Ehninger1212
Jake
Houston, TX
I was more talking about using existing aftermarket winches on the truck.. Warn, superwinch ect. The plaid mode part was a joke not serious, i wouldnt want a high speed winch
Do you know how the current 12v battery is charged? In most winching situations its really about how powerful your charging system is, the battery is just a buffer. Without the Alternator and engine running they will kill any battery FAST.
ajdelange
A. J.
Virginia/Quebec
EE (Retired)
There is a DC/DC converter which you can think of as a battery charger supplied by 385 VDC.
That would be the case here too so the ability to have a winch is going to influence the design of the DC/DC converter. Note that the CT is going to have an air compressor too. Will it be a real air compressor that can run air tools (the fact that there will be 240 V outlets suggests that it will) or just a dinky little thing that can handle a flat? Put air compressor, inverter and the ability to install a winch together and you have strong indications that he low voltage system in the CT is going to be appreciably different from what's in the current Tesla lineup.
Ordinaryguy
Peter
Canada
Yeah, I’m thinking outside the box. Tesla could do something different for winching besides having a warn winch hanging off the front. Tesla is building entire vehicles in China haha. You don’t know much about winches or off reading
