Why PPF on CT without paint , does not wrap suffice ?
panthar
RS
Model Y , CyberTruck
I know its personal preference but I was thinking that having a CT without a paint, I should go for a wrap , which is less expensive that way I can keep changing colors.
In price of 1 PPF, probably can change wraps 2 or 3 times ...
JTzinski
Jeremy
Ankeny IA, USA
Model X 100D --> 2024 Cybertruck Tri-Motor FSD
Director
I don’t know much on the topic, but I’m pretty sure that the advantage to PPF is the self-healing properties that you don’t get with vinyl wraps.
getsometom
Tom
PPF is much thicker than regular vinyl wrap. Not only are you getting self-healing on light scratches when heat is applied usually from the sun, it is tougher to damage and harder to chip.
elyliu
Los Angeles, CA
CyberTruck AWD, Model X 90D, Model 3 AWD
Vinyl is definitely the way to go if your main objective is looks. And to your point, the SS doesn’t need protection from impact. For the same price you can change it more times and there are more color options with vinyl.
I went an hybrid route. Vinyl the entire car plus clear PPF on top of the vinyl for just the hood to protect the vinyl from rock chips.
rjhoskins
Ryan
2018 Model 3 Performance 2023 Model S Plaid 2024 Cybertruck AWD
Interesting and neat idea.
Pops
Houston, TX
MY, CyberBeast
Here is a good video that shows why you might want to consider PPF over a wrap, or at least wrap with PPF on top in the front. In just a couple months he already had rock chips in the wrap.
