ButterEV
- Eric
- Jan 23, 2024
- California
- Website
- www.youtube.com
- Cybertruck
It is a bummer, Thanks for your video.
I was disappointed. I’d much rather charge at the campground rather than having to find a local supercharger then leaving the family to go chargeIt is a bummer, Thanks for your video.
Then we need to find a good load sharing smart splitter.I was disappointed. I’d much rather charge at the campground rather than having to find a local supercharger then leaving the family to go charge
If campground power post only has one 220/240VAC outlet, connecting the Cybertruck first and RV into Cybertruck is inefficient (AC to DC, Cybertruck inverter back to AC to power RV), stresses Cybertruck electrical system, and also means if you need to make a trip in Cybertruck you need to unplug both Cybertruck & RV.I was disappointed. I’d much rather charge at the campground rather than having to find a local supercharger then leaving the family to go charge
Nice!The Ford F-150 with Powerboost is amazing for the trailer set up. You get all the torque you need from the electric side (570 lb-ft). 27 gallon tank to go the distance. 7.2 kW plug in power in bed with 30 Amp connection. Tow mirrors.. The back seat is also roomier than the Cybertruck. It’s why I’m also keeping that around.
I like this idea. When the electrician comes out to install PowerShare setup at my home I’ll inquire about this 2-socket box.If campground power post only has one 220/240VAC outlet, connecting the Cybertruck first and RV into Cybertruck is inefficient (AC to DC, Cybertruck inverter back to AC to power RV), stresses Cybertruck electrical system, and also means if you need to make a trip in Cybertruck you need to unplug both Cybertruck & RV.
A better solution might be to have an electrician make you a small portable 2-socket panel box that you has plug into the campground power. This portable box would allow both Cybertruvck & RV to get power directly from campground power. You might have to lower Cybertruck charge rate (lower amps) to keep total power usage with rating of campground power post.
A slight variation for 2-output portable box is to have 1-socket output for RV and the 2nd output be an actual hard-wired Tesla Wall charger gen 2/3. This would mean you don't have to constantly use your Tesla mobile charger. The wall charger might be a little more power efficient, save charger config settings, and allow better remote monitoring of charging.If campground power post only has one 220/240VAC outlet, connecting the Cybertruck first and RV into Cybertruck is inefficient (AC to DC, Cybertruck inverter back to AC to power RV), stresses Cybertruck electrical system, and also means if you need to make a trip in Cybertruck you need to unplug both Cybertruck & RV.
A better solution might be to have an electrician make you a small portable 2-socket panel box that you has plug into the campground power. This portable box would allow both Cybertruck & RV to get power directly from campground power. You might have to lower Cybertruck charge rate (lower amps) and/or RV power usage (use only one AC) to keep total power usage within rating of campground power post.
Spot on about stressing the CT more than necessary. Having a splitter box is absolutely what should be done. De-rate the CT during the day, and maybe bump it up at night when you are sleeping to get the best of both worlds.If campground power post only has one 220/240VAC outlet, connecting the Cybertruck first and RV into Cybertruck is inefficient (AC to DC, Cybertruck inverter back to AC to power RV), stresses Cybertruck electrical system, and also means if you need to make a trip in Cybertruck you need to unplug both Cybertruck & RV.
It would be easier/less expensive to just install a 240V outlet on the camper and then charge the Cybertruck from there. I would probably install a 20 amp 240V outlet so I would still have 30 amps for the camper but if the camper had low power needs, you could install a 30 amp 240V outlet for charging.Then we need to find a good load sharing smart splitter.
This is also a great idea. I’ll ask the electrician about this option as well. ThanksIt would be easier/less expensive to just install a 240V outlet on the camper and then charge the Cybertruck from there. I would probably install a 20 amp 240V outlet so I would still have 30 amps for the camper but if the camper had low power needs, you could install a 30 amp 240V outlet for charging.
At the RV parks I've been to, they usually don't mind if I plug into a free post for a while to charge the Tesla.I was disappointed. I’d much rather charge at the campground rather than having to find a local supercharger then leaving the family to go charge
This place had 100% occupancy otherwise I would’ve askedAt the RV parks I've been to, they usually don't mind if I plug into a free post for a while to charge the Tesla.
