CTFS2024
I found this screen protector on Amazon. It said it's tempered glass 9H. Did anyone purchase this yet? If yes, any inputs?
https://a.co/d/5IqlKNp
UPDATE after installation:
I finally installed it, and it looks good. It is matte, so no reflection from the sun which is a plus. It is Tempered glass. The only draw back is the installation instruction is not clear, the screen protector in my opinion is a little smaller than the screen itself for the front, the back screen is perfect.
I like it. So I would recommend this as "temporarily" solution until more options are available.
Pros:
1. Does not impact the "touch" responsiveness.
2. Matte - you can see it clearly (no reflection) during clear sunny day
3. If you messed up (particle, not aligned well etc...), you can remove it at a corner and reinstall -- it does not affect the performance of the protector
Cons:
1. Front screen protector seems to be a tiny bit smaller than the screen itself
2. Installation instruction is not very clear, it could be improved, but if you have installed any screen protector previously (eg phone protector), you can figure it out, but the large screen makes you nervous and want a clearer instruction. I try it at first, found there is a tiny particle underneath, I lift up a corner, remove the particle and put it back with no issue.
Pros:
Cons:
