Rotopax mounted on bed L-track?
81u80x
Los Angeles, CA, USA
Cybertruck AWD Foundation Series (VIN 021xxx)
Has anyone found a solution to mount a Rotopax on the L-track?
I'm trying to work out a solution using something like this L-Track Double Lug Threaded Stud Nut + a Z bracket like this Heavy Duty Steel Black Z Brackets to get the Rotopax to stand out of the L-track a bit so it can stand vertical as the bed sides are not + the a basic rotopax mounting plate
It's getting quite hacky even though it may work. Any better solution you may have seen?
I understand the alternative of using the Molle panels and mount it there, but wondering if there's anyway to use the L-track. I'm interested in mounting the Rotopax close to the tailgate for easy access.
