- Ed
- Dec 30, 2023
- Gainesville Ga
- Model 3, Model Y, Cybertruck AWD
- Consultant
And you are absolutely correct.It was over 90F today. I live in the mountains, not the city, of Santa Cruz. It was 70F on the beach.
When you install a Powerwall, the circuits it's protecting are selected then. It's not just plugged into a whole house unless the house draws less than the output. And I don't know about your house, but mine can't draw 9.6kW of power, let alone continuously.
Even AC doesn't use power continuously. The fans and pumps cycle on and off. And thermal dynamics being what they are, it's best to design a house to have a thermal mass so it doesn't need constant, emergency heating and cooling.
It's all about balancing that.
And I say that as now, the power is out, and has been for an hour and a half, and I'm on battery, and PG&E says the power won't be on for another two hours. The house isn't going to suddenly heat up because it's placed in the shadow of the trees, and I cooled it down last night to have the thermal mass to make it through the day.
The vast majority of houses will do just fine on a Powerwall. Especially one that has its own island of solar panels to back it up, and that means Powershare is only for when things get dire and so it doesn't need to be so 'automatic' other than having it plugged in.
But go back and read the first post. At what point did anything get said about having to move loads around?
And no, AC doesn't necessarily use power continuously. But on hot days with a zoned system, mine has been known to. And definitely on cold nights (it's a heat pump) and the supplemental strips engaged, it definitely can stay on 12+ hours.
Everyone is different. Any use of Powerwall or Powershare should be evaluated by a professional.
Not a few posts on an Internet forum!
