Possible Future Remedy for Cold Climate Range Issues….
Diveflyfish
James
Wisconsin
2024 CyberBeast 2011 BMW 335d
Dentist
Now think of this item, as applied to a CyberTruck…………. Perhaps there is more to the choice of SS than meets the eye. Let’s just say, you wanted to use materials that would potentially minimize the need for recycling by simple longevity……. Add a Thermionic Nuclear power source and you have a system that could simultaneously charge and keep things warm in cold environments…….. ?like space…..or Wisconsin? ah, a mini SNAP generator……… ?!
Perhaps there is a future for a NUCLEAR augmented TESLA ( NASA-SpaceX )
https://technology.nasa.gov/patent/LAR-TOPS-335
CyberTruckeeTheOne
Andrew
Milpitas
4runner
I myself was waiting for flux capacitor.
I just saw that China was getting ready to produce nuclear batteries.
I believe that it was a few volts at a couple of milliamps. But lasts 50 years.
CyberTruckeeTheOne
Andrew
Milpitas
4runner
I wonder if they have stolen our flux capacitor technology.:devilish:
Nabilriaz69
Nabil
Toronto
Tesla model x
The Nuclear batteries is very old Technology , only provides very small power. CATL and BYD are working on Sodium Batteries instead using Lithium , that is way cheaper than Lithium and in abundance. That will be game changer. But Energy density is lower for Sodium Ion batteries than Lithium.
Diveflyfish
Diveflyfish
James
Wisconsin
Dentist
Agreed, however would it be possible that a small nuclear cell system could be used for keeping a means to have a source of heat used with the heat pump system to minimize need to use battery energy for maintaining optimal cell temps in cold climates?
JB
Tesla
. Professional Hobbyist
If heat loss was a big problem in colder climates I would rather they use insulation instead to contain it. Normally you set the car to preheat everything before disconnecting the chatge cable. That way everything is warm already.
You cold also use a heat recovery ventilation system to keep hearing losses to a minimum.
The only heat you'd have to add then is what heat you loose along the way that leaks through the insulation. Helps for keeping the car cool in warmer climates as well, and would generally cost less than adding something else. Would also improve cabin noise etc. and reduce heat loss when using camp mode and even when charging.
Otherwise not really a fan of anything that produces ionising radiation. Rather go the low/no energy pathway and avoid high potentials altogether.
