cvalue13
- Aug 17, 2022
- Austin, TX
- F150L
- Fun-employed
A recent track video showed some unusual dark spots within the bed of the Cybertruck.
The dark spots were clearly rectangular, paired across the width of the bed, and spaced on the length of the bed at three locations:
Rewatching the investor day prototype video, I noticed not only that these dark spots are in the locations of trim covers, of the size and type similar to those rectangular trim covers found on the top table trim of each of the sails. But also that there's also a 7th (but not 8th) such rectangular trim plate on the far driver's side of the tailgate:
I could find no single frame of video that clearly shows the other 6 such trim pieces in the bed floor, though they're visible (as in the track photo above) in various angles.
Together, these 7 trim caps (?), 6 in pairs in the bed, the 7th on the tailgate, are evenly spaced throughout the bed about as follows:
THOUGHTS ON PURPOSE?
Off the cuff, the "purpose" of these could range from:
The one-sided trim cover in the tailgate was a to me more interesting bit, as it doesn't quite square with being a mere mounting bolt cover (on only one side), and for me the lack of info or clues on tailgate ramps has me curious about all things tailgate.
BTW, @JBee - speaking of the mounting points on the upper table of sails: i realized while drafting this that if those are in fact mounting points, they would presumably be above/into the casting, meaning the casting may be at the outermost edge of the sail volume, as opposed to the innermost edge?
- near the bulkhead
- ~ just behind the rear axel, and
- just forward of the sub-bed storage area hatch
- benign trim covering points for factory mounting bed to casting (but tailgate?)
- the location and spacing would be consistent with where traditional beds have their mounting bolts
- if so, there's presumably 2 more such points 'hidden' under the storage door
- tie-down points for customer use
- accessory mounts
- combos of the above
