DFWBrad
- Brad
- Jan 17, 2024
- DFW
- 488 Ferrari (current) - CT/MS22/M3P(sold)
Not sure if someone else is doing this or not, but I'm going to keep a thread for my own issues that I've had with this truck so far with less than 4 days of ownership on record (5/5/24 pickup)
Side note: whomever in Frisco is telling people they paid $250k for this truck, you're wild
- Tonneau cover issue (semi-resolved): My tonneau would stop about 1-2 inches from the end then bounce back to about 5inches. It eventually just stopped working... @CyberGus was kind enough to have a solution for the stuck portion HERE. As for the cause of it, I have an appointment June 5th to dig deeper. Also with this, there is a bulging of the trim around the tonneau area (by the button) so curious if that's a factor or not.
- Camera Failure (resolved): One of my cameras was failing to calibrate due to some issue, took that in on 5/9/25 and got it fixed within 2 hours. You have to go into service for that one.
- Window Trim Bulging (unresolved): The trim above my right side rear window is bulging down about an inch over a 3-4 inch area. I tried to just push it back into place but it won't budge, so letting Tesla hopefully deal with it on June 5th as well
- Window Rattle (unresolved): Driver side window (when down) rattles pretty bad while driving. Can't source the issue, will hopefully be looked at June 5th.
- Suspension Failure (Potentially Self resolved, will wait and see): Was sitting in a parking spot at my business, went to leave and got "Air suspension unable to raise" error code while driving down the road. Some other threads are saying just let it be for a bit and this might go away, but I'm not that hopeful with my current state of the truck and have also added that to my June 5th list of things to fix...
