Iron remover, is it ok to use regularly
machmax
JP
Tampa, FL
‘24 CT (Non-FS)
I tested the Meguiars Iron Remover and it works really good. Not only it removed the iron spots but also the discoloration with very minimal effort. It obviously does most of the work in some chemical reaction level so it left me to wonder if I use it as my regular “car wash” routine, will it have some negative effect on the SS skin of the CT down the road.
Anyone have any knowledge about this?
Tesla Cybertruck Iron remover, is it ok to use regularly IMG_9314
Tesla Cybertruck Iron remover, is it ok to use regularly IMG_9315
Tesla Cybertruck Iron remover, is it ok to use regularly IMG_9316
Tesla Cybertruck Iron remover, is it ok to use regularly IMG_9317
JMIA
Justin
Miami, FL
2024 Cybertruck AWD
Thats a great question, im also wondering the same
koolio
Greater Boston, MA
I believe it’s perfectly fine to use regularly because the liquid solution is designed to interact with iron particles / deposits.
It won't hurt the stainless at all. Remember, it's formulated for cars with much more fragile clearcoats so it won't be too acidic for the Cybertruck's bare stainless steel. I would just use citric acid (or Citrisurf if you want a pre-mixed formula). All of these products should be kept away from things like rubber and plastic or diluted with water if it gets on them.
machmax
machmax
JP
Tampa, FL
‘24 CT (Non-FS)
T
Thanks, that’s a good point and good note about the plastic.
