iPhone Widget - how to show different vehicles?
Bizarrkley
NorCal
Cybertruck Foundation AWD
I have a Model S in addition to Cybertruck. The widget on my latest version of IOS only shows the Model S (unless I tap on it and then slide to the CT). Any way to choose the CT as the "default" vehicle in the widget. I'd even be open to two widgets; one for each vehicle.
armywildcat
Ambrose
Wichita, Kansas
Finance
Mine opens to the last one I was viewing before I closed/minimized the app. Not sure there is a default setting you can change.
armywildcat
Ambrose
Wichita, Kansas
Finance
On the Widget it also gives the option to select default. Select edit and then you can select which vehicle you want to display.
AlmostHuman
Earth
Model X, Cybertruck
Human
You can edit the widget and change the vehicle it is showing by touching the name of the vehicle when in edit mode. You can also just add a second widget with the other vehicle.
Tesla Roadster 2nd gen iPhone Widget - how to show different vehicles? IMG_8406
Bizarrkley
Bizarrkley
NorCal
Perfect! Thank you!!
