- Ace
- Jan 22, 2025
- Arizona
- 2024 foundation AWD, 2024 model x
- Trauma Surgeon
No. I went through the grommet tooUnderstood. The river 2 pro is probably overkill for my usage, but I think I would like to use the power from the frunk supply for a cleaner install. I'll use the battery setup you describe but will mount the buck converter in space behind the frunk and run a lead for the battery into the cabin. I've seen things that state there is a grommet in the firewall to allow access, but I think your pictures showed going via the door jamb. Any reason why?
there are both an ac and dc cable there that are fed by the frunk power station which is powered by the frunk feed.
