Fleet Recommended Ride Height and Handling
rovert43
Trevor
Covina, CA
2024 Cybertruck Foundation AWD
IT Mamager
Hello, you may be like me and constantly having to update your ride height and Handling presets and custom. I've noticed that my CT will automatically adjust itself sometimes, however as an adventurer I find myself constantly changing manually based on if I'm going up a treacherous mountain road I'll want to go into Sport mode, then as I pull off the highway and hit a trail i have to go into Baja rough, then eventually or periodically go into Overland.
It would be a great addition to add a feature that is fleet based to pop up recommended ride and stability settings to ease the interaction between the driver and the screen especially while performing intense driving situations.
RoboTaxi
Kansas
Beast when the gods bless me
It might automatically adjust because you adjusted the ride height at that spot in the past. It saves the info. You can clear the history.
It definitely does.
Oh, please, no. I like picking my own suspension settings for a given environment. Having recommended suspension settings would be like having equalizer presets for the stereo recommend what others use, nobody would ever agree on the same settings!
