Error Codes, truck brakes, steering issues
Cybertruck 1974
Everywhere
Had my share of errors last night. 2200 mikes...traction, stability, braking, steering codes come up and braking reduced to 50%, steering stiffer, throttle not responsive. Stopped and put in park. Put in drive and codes went away and truck went to normal. Charging now and will take to tesla asap.
Gigahorse
AWD
Were your error codes similar to the ones others posted?
By "throttle not responsive" do you mean it was a little slower or did the speed get reduced to a max of 15mph?
truck
Tesla Model X 2017 100D LR/S 2015 P85D/Cyberbeast
What are all these ghost errors? Is it an actual issue that needs to be physically fixed or is it a software issue?
Gigahorse
AWD
Could be either, could be software relaying a false positive, or could be a mechanical issue. The problem is the system is built in such a way that both need to function and if one goes the system can not operate without both. Advantages and disadvantages of tech, the good news is with all the electronics they have an easier time diagnosing.
Cybertruck 1974
Cybertruck 1974
Everywhere
not sure at this point. Put in for a service. Will post when all figured out. I believe in past someone posted, where I tried to find on this forum they had similar issues and Tesla did a quick repair (software)? reboot
Cybertruck 1974
Cybertruck 1974
Everywhere
it was jittery on accelerator.
CyberVeteran
Jason
2024 Tesla Cybertruck
Health Care
I have had this happen 3-4 times and the first time was on 4/4. My truck is in the service center now, and the technician stated there was one yesterday with the same issue and that it is likely a software bug.
Cybertruck2024
Buffalo
Ford Lightning and Model 3
One challenge with Tesla service is "software bug" is often noted as the reason something isn't working. My camera was having issues going off and on with my Model 3, was told it was a software bug. Two updates later and the problem persisted. They finally replaced the camera, which was actually the problem. Now I'm skeptical when they tell me software bug.
Cybertruck 1974
Cybertruck 1974
Everywhere
Hi, Yes i had mine in service to pick up a spare tire and they looked into the codes and stated it needed a firmware update which already happened and I haven't seen it happen again. Fingers crossed.
