Liberty1
- Jun 14, 2024
- St Petersburg, Florida
- 2025 Cybertruck AWD
I am contemplating buying the Tesstudio console 110V charger hub but I have the commonly available fingerprint safe already installed in the console and that complicates the cable management for the charger hub since the hub needs to plug into the 110V outlet that is now enclosed within the safe. I have seen a couple of videos on YouTube where the presenters have either messily cut through the top of the safe or, alternatively, jammed the cable through the existing USB cable hole but they then report that the safe door doesn't open as smoothly.
Has anyone successfully (and cleanly!) drilled through the top of the safe to create a wider hole to run the power cable from the console power bank and, if so, did it require a special bit/equipment?
