mm767cap
- Miles
- Jul 6, 2024
- Denver, CM
- Dual Motor CT, Range Rover LWB
- Pilot
Hi All,
Another concern: My front dome light is inop. No big deal, I've got a service appointment and I'm sure they will fix it. My question:
When you select "AUTO" for the dome light, do the back lights come on dim when you open the door? Mine are quite dim until I select "ON" in the menu, and then they come on full bright. Is this normal? Is there a way to select full bright when you open the door and then have them go out when you close?
Thank you!
Thank you!
