Sirkevin
I was just at the service center and noticed the new cyber trucks are getting upgraded features that are not on the original cyber trucks.
for example, the rubber trim on the back of the glass for the tonnage is now a hard rubber strip. The older cyber trucks had the rubber foam that easily tears off. If you happen to get a tear in your insulation, the center is going to replace your glass. this causes the unpainted surface below the rubber to become visible. The new ct panel is painted all the way down and had in additional rubber strips.
It also appears that they've upgraded the tonnage cover to be more leak proof.
The bed seems to be of different Texture than mine. And the glass roof looked different and more flat.
they are also have the upgrade windshield motors. And some electronics I've been told.
I expect overtime. Everybody will get retrofitted to the new parts as a become issues.
