ajdelange
- A. J.
- Dec 8, 2019
- Virginia/Quebec
- Tesla X LR+, Lexus SUV, Toyota SR5, Toyota Landcruiser
- Occupation
- EE (Retired)
Although I didn't get an answer as to the battery if I assume that @Luke42 is right (and that certainly seems plausible) and that there are 5 of these packs in series that implies, per the specs on the vendor's sheet, that the discharge cutoff (0% SoC) is 99.4V and that the charge cutoff limit (100% SoC) is 126 V then these 120 V DC/DC converters can potentially charge this pack to 77% SoC. Again, per the specs, the pack's capacity would be 26.5 kWh. Each hour of charging at 2A from each converter at 120 V implies 480 Wh added:. 480/26.5 = 0.0181132 or about 1.8% per hour. Where I live I get 2 hr FES (Full Equivalent Sun) per day in the winter and 5 in the summer so that would mean 3.6 to 9 % charge added. As an experiment i'd say it's absolutely worth a shot but I cannot go so far as to recommend that you undertake it as I don't believe that someone who doesn't know the difference between AC and DC should be playing with electricity - even at 120 V.
