Brake Malfunction; hit light pole
It's conceivable that regen could have been limited. That's expected at high SoC and can be temperature-sensitive.
There are even some long-time Tesla drivers at TMC that believe regen was reduced in the last software update:
https://teslamotorsclub.com/tmc/threads/regen-braking.323598/
although my experience with regen shows it to be very effective.
pricedm
Adam
Denver, Colorado, USA
To everyone saying pics or it didn't happen... what actual difference would the picture make? Would you believe OP if there was a picture of the truck smashed into a pole? That would somehow make you believe that the brakes didn't function and it was not operator error?
I'm not sure what evidence would be sufficient for everyone to be on the same page with this one. Lots of people swore their teslas accelerated for no reason as well when it turned out they hit the gas instead of the brakes.
I don't give a flying F*K about photos. However, the logs will tell the story. Tesla has the logs....yes, all cars have this info. Will be interesting to hear what is published.
Jow
Jerry
WI
'94 Bronco, '24 CT
Biz Owner
what time of night was this?
FutureTruck
GA- USA
Tesla MX P, Lucid Air GT
Wow some of you are vicious. You can like Tesla without calling someone that has an issue with them a heretic. Smashed truck is bad enough without people calling it a hitpiece.
CybertruckRN1127
Palos Verdes Estates
Model S, Model 3, Model X
Everything was spectacular i enjoy the vehicle and im glad i am not injured in any way. (airbags did not deploy) definitely have whiplash.
again i can only explain it as brake malfunction and how it happened, there was no warning signs , nothing, didnt decelerate fast enough, and brakes didnt engage fast enough, there was a delay,
There could be air in the brake lines. Not sure how it happens, but I had it in my old Toyota before (was fine for 40k miles and no recent fluid changes). Was scary when it happened to me, but got pressure back after pumping it 5 or 6 times. After that, I had never experienced it again.
Edjcyberbeast
Edjcyberbeast
E
Sac
Self
Regen was working but it was limited it was different than before ( I’m doing a bad job of explaining), hence the application of brakes which also had a delayed feeling. I’m glad to be uninjured ?
Feeling a bit sore
Still love the truck though.
Edjcyberbeast
Edjcyberbeast
E
Sac
Self
I also requested the logs
RayzorBEV
Electric Bum
Guys I had my Truck for less than 350 miles. something happened i cant explain... I was driving like usual and when coming into a turn releasing the accelerator but the speed wasnt reducing... so i pressed the brake... but it didnt engage.... until it was too late and i hit a signal light pole, also airbags didnt deploy.
Here are some pics of damage
All Tesla has so called Black box that continously record the vehicle's usage history and vital statistics so they can pull up information pertaining to the vehicle prior, during and post accidents.
Edjcyberbeast
Edjcyberbeast
E
Sac
Self
Yea they have a team looking into it right now.
I find out what their diagnostics and review of the issue is.
pricedm
Adam
At the beginning the OP was a troll because Tesla is perfect. OP post pics and now he doesn’t know the difference from brake and gas because Tesla’s are so sophisticated ???
Not at all. The issue is (Audi et al) most cases like this are pedal misapplication. Yes, it could be mechanical failure, software failure, etc. However, the most simple explanation is usually what occurred. In this case: pedal mis-application.
Best for all to withhold judgement (ha!) until facts are known.
