JCERRN
- J
- May 3, 2021
- Around
- Yeah
If you change your mind on this project ill buy it off you, dm me! But yeah those are seemingly thick stranded copper wire, should be fairly easy to strip the ends and splice/ heat shrink wrap them. Soldering is fairly easy but requires heating the wires to above the melting point of the solder so it flows onto the wire. Flux helps. Just be careful heating the proximal aspect as its not clear whats behind that plastic cover, the wire might have 2 more inches then be soldered to a board, no idea unless you open itOk. So Pete and the other scrapers were right. It worked but I did a very boneheaded thing.
Right towards the end I lost control of the blade and hit the wire transecting the black and green. I carefully dissected it for exposure which is how I know it’s black and green. It’s rather close to the bar unfortunately.
I don’t have have that kind of stripping and soldering skill. Anyone have any advice or did I just throw away this bar?
