YDR37
- Dec 29, 2023
- California
- Tacoma
That's true. The BMW i3 used a 2-cylinder, 0.70-liter motorcycle engine as a generator. OK for recharging the battery, but you wouldn't want an engine like that to be the sole source of power for even a compact car.One of the drawback is that you need to have a generator able to produce
enough energy to fully move the truck when the batteries are empty,
otherwise you will have to drive at a reduce speed, like the BMW i3 low speed issue.
Note: The "BMW i3 low speed issue" refers to a known problem where the optional Range Extender (REx) version could lose significant power and slow to around 40-55 mph, especially under load (uphill, with passengers, or cold), often triggering a "Reduced Engine Power" warning as the car tried to manage battery charging, sometimes leading to lawsuits over sudden,unexpected power reduction
The RAM 1500 REV will use a 3.6L Pentastar V6 as a generator. That's been the base engine in the ICE Ram 1500 since the 2013 model year, so seems like a better match.
