It just makes the metal sticky and have toxic run off.Anyone try it?
As l recall, WD40 was used by NASA on Friendship Vll when John Glenn circled the Earth. Good enough for John's Spaceship, then it's good enough for my CT SPACESHIP!If it's good enough for Starship it's good enough for Cybertruck. ?‍
What do you want to achieve? A "wet look"?Anyone try it?
I've noticed WD40 is good at removing dirt and if you don't want the shiny look, after wiping it off it will still protect from finger prints.WD40 is fine on the CT, but not as a cleaner. If your goal is to protect the stainless, go for it! If your goal is to make it look clean, run the other way ?
Also, yes I've done it just prior to a wash as a preconditioning. I thought maybe it would help with fingerprints after the wash like a sort of SS wax. I was wrong, the soap to just remove it all in one go. Didn't hurt or help. But it certainly isn't going to make it shine
It will! But it'll also gather dirt if it isn't washed offI've noticed WD40 is good at removing dirt and if you don't want the shiny look, after wiping it off it will still protect from finger prints.
