MEDICALJMP
- Jeff
- Apr 28, 2020
- Omaha, NE
- Toyota Avalon, Rav4, Tri-motor Cybertruck
- Nurse
TIMELINE:
0:00 Introduction
0:27 The rear motor of the Model 3 and Y
1:08 The input shaft with 31 teeth
2:00 the input shaft SKF bearings for a rotor speed of 18,447 at 262 km/h (163 mph)
2:40 The countershaft and gear with 81 teeth
3:00 The input shaft to the countershaft gear ratio of 81/31 = 2.6129:1
3:10 The countershaft pinion gear with 24 teeth
3:15 The ring gear and differential case with 83 teeth
4:30 The countershaft to ring gear ratio of 83/24 = 3.4583:1
4:43 The overall gear ratio = (81/31) x (83/24) = 9.0363:1
5:03 The published gear ratio is incorrect
5:48 The CV half-shafts connect to the differential side gears
6:46 MUST SEE: two cool Permanent Magnet rotor demonstrations
8:05 The modular design of the motor shafts and rotors
8:25 MUST SEE: Watch as a rear motor is changed into a front motor
10:32 The differences in the modular motors
11:35 See what a permanent magnet does to the Induction Rotor
11:55 An aluminum core front induction rotor on the Model Y
12:13 There are at least three different rotors for the Models 3 and Y
13:54 See the rear motor inverter and where it attaches to the rear housing
14:45 The matching part numbers of the rear inverter and the stator (A matched set)
15:15 The three different power and torque levels of the Model 3 and Model Y
16:15 MUST SEE: See the front motor inverter attached to the rear housing!
17:37 the common bolt pattern and opening for the stator housings
18:30 The oil-cooled stator and ATF-9 fluid
18:47 The interchangeable transmission heat exchanger
19:13 The interchangeable variable speed electric oil pump
20:25 The interchangeable spin-on oil filter
21:06 What is not interchangeable between models
21:20 The rear drive-unit is mounted parallel with the ground
22:20 The front drive-unit is mounted upside down and on an angle
23:05 The matching part numbers of the front inverter and the stator (A matched set)
26:30 Additional EV training opportunities at https://www.weber.edu/evtraining
26:58 Video summary and donation opportunity
