Stickercity
- Dean
- Jul 24, 2024
- Los Angeles
- Teslay model 3
- After Market Automotive Services
Introducing the TOProtect Cybertruck Cargo Front Inner Door Pocket Protection DIY Vinyl Fascia Overlay Kit — your ultimate solution for durable and stylish protection! Designed specifically for the Tesla Cybertruck, this kit offers a robust bed liner spray look that not only enhances the interior aesthetics but also provides superior protection against scratches, dings, and wear.
ENHANCED LOOK & PROTECTION: This premium 23 mil semi-gloss black vinyl film gives your Tesla Cybertruck front door inside pocket area a rugged, textured, and aggressive off-road appearance. The film mimics the look of a spray-on bed liner, significantly enhancing the visual appeal of your vehicle. Additionally, it offers durable protection against scrapes, and scratches, ensuring your door pockets stays in pristine condition.
EASY DIY INSTALLATION: This kit offers an easy at-home installation, covering the inner pockets of the front doors. It includes a squeegee, step-by-step instructions, and a video tutorial link for a pro finish in under an hour. The repositionable adhesive backing allows for adjustments, and the thick vinyl film ensures a smooth, wrinkle-free application. Ideal for both beginners and pros, it installs quickly and can be removed without damage—just lift and peel.
CUSTOM FIT FOR CYBERTRUCK: Designed specifically for the 2023 and up Tesla Cybertruck models, the precut pieces fit perfectly over the front door fascia plastic trim pieces without the need for removal. The kit smoothly hides joining seams cleverly along the body lines, providing a clean finish that integrates flawlessly with the black plastic trim.
RESISTANT & LONG LASTING: Engineered for outdoor use, the TOProtect film withstands dirt, debris, and various weather conditions, ensuring reliable performance and protection. With a 3-5 year outdoor life expectancy, this film maintains its integrity and appearance in extreme temperatures, UV exposure, and moisture, making it a robust and long-lasting solution for your Cybertruck.
IMPORTANT NOTE: This kit is designed to overlay on top of your existing trim and does not fully wrap around the edges and corners due to the material's thickness. You will have approximately 1/8 inch of the factory plastic trim visible around each piece and between some of the joints where some of the pieces meet. However, the kit blends well with the exposed black part of the plastic trim, ensuring a seamless and cohesive appearance.
GUIDELINES: Installation takes about 20 minutes. Apply the film in 65°F–75°F for best results. In colder temps, warm the plastic trims and film with a hair dryer or heat gun for better adhesion and smoother application. Hand washing is recommended to maintain the film's appearance and durability. The film won't adhere to plastic trims with ceramic coating, so remove any existing coating before applying to ensure proper adhesion.
Very Easy Installation.
Get yours here
Get yours here
