πŸš€ Upgraded Cargo Divider's Most Comprehensive Review Video: Solved the OEM Issues that bother you most! 🚚
T-Launch
Hi Cybertruckers,
Joe from Teslaunch.net ! I’m thrilled to introduce the upgraded version of the Rear Trunk Vault Cargo Divider, made specifically to address the challenges many of you have experienced with the OEM design! ?
While the OEM Cargo Divider has its strengths, it often falls short when it comes to compatibility with floor mats and ease of installation. The tight tolerances make installation/removal tricky, and the lack of adjustability can be a headache. Recognizing these pain points, we’ve developed a set of upgrades that drastically improve both functionality and fit. Here's what sets this new version apart:
? Key Upgrades:
1.Flexible L-Track Positioning: You can place this divider anywhere along the L-track, and easily adjust its length by tightening the sides – giving you a perfect fit every time.
2.Robust support: Unlike a flimsy net, this divider offers robust support, able to hold heavier items and keep them securely in place, no matter how bumpy the ride gets.
3. Vault Mat-Friendly: It’s compatible with vault mat, so if you're using your Cybertruck with carrying a vault mat, this divider won’t get in the way!
4.Adjustable Rubber Base: With adjustable rubber feet, you’ll avoid any misalignment, ensuring that the divider stays stable while fitting seamlessly with your floor mats. No snagging, just smooth handling! ?
Tesla Cybertruck πŸš€ Upgraded Cargo Divider's Most Comprehensive Review Video:  Solved  the OEM Issues that bother you most! 🚚 Teslaunch Cargo Divider (1)
Tesla Cybertruck πŸš€ Upgraded Cargo Divider's Most Comprehensive Review Video:  Solved  the OEM Issues that bother you most! 🚚 Teslaunch Cargo Divider (2) Tesla Cybertruck πŸš€ Upgraded Cargo Divider's Most Comprehensive Review Video:  Solved  the OEM Issues that bother you most! 🚚 Teslaunch Cargo Divider (3) Tesla Cybertruck πŸš€ Upgraded Cargo Divider's Most Comprehensive Review Video:  Solved  the OEM Issues that bother you most! 🚚 Teslaunch Cargo Divider (4) Tesla Cybertruck πŸš€ Upgraded Cargo Divider's Most Comprehensive Review Video:  Solved  the OEM Issues that bother you most! 🚚 Teslaunch Cargo Divider (5)
Tesla Cybertruck πŸš€ Upgraded Cargo Divider's Most Comprehensive Review Video:  Solved  the OEM Issues that bother you most! 🚚 Teslaunch Cargo Divider (6)
We’ve taken all the feedback from the Cybertruck community and created a solution that solves the old one's issues once and for all. Whether you're carrying gear, camping equipment, or tools, this upgraded divider will keep everything locked in place and secure.
? Learn more: Cargo Divider For Cybertruck
By the way, dscover Teslaunch full range of Cybertruck accessories here(New arrivals every week!): https://bit.ly/48sNi4z
Discount code: Use TESCT to get 10% off sitewide.
Thanks
Joe
Teslaunch.net
JackCypher
Jack
Cybertruck Foundation
CEO
Good updates. I have the Tesla OEM one and clearly it was not really 'used' by those who designed it. It 'works' however essentially, it gets into it's own way.
The OEM one is extremely sensitive to the bed deck height - even after Tesla replaced my deck - the divider still binds.
It would have been nice to put some alignment marks - so you can align the extending pins to the rail holes - before you commit to closing the pin lever...
The other issue is the standard Molle squares in the panel is too small to get a standard tie down hook into - I mean you can..but it's 'tricksy' as the hobbits say...
T-Launch
T-Launch
Thank you very much for your comment and recognition of this update. May I ask what the size and type of standard tie down hook are? Let me see how we can optimize it. Your opinion is really valuable to us!
JackCypher
Jack
CEO
Tie Downs: The ratcheting kind you find at Home Depot, Rhino - those hooks are large about 2.5" across - so they don't easily hook into the molle.
